Author Topic: FS: Black and Clear IL Push Buttons (Wyoming, ships)  (Read 8069 times)
« on: April 07, 2011, 07:06:33 pm »
I have 26 10 of these pushbuttons. They are the extra parts combined from the buttons I used for my project. These are brand new and never used. 24 8 have 50 gram micro switches and the other 2 can either be 20 gram, 75 gram, or 125 gram (I only have 1 20 gram switch and 1 125 gram switch). These just came from Paradise Arcade Shop. The plungers are clear and the barrels are black. You can light these with the IL button LED boards Paradise sells, but to do so you'll have to drill a small hole in the base of the black barrels to allow the light to pass through. Asking $1.75 each +shipping of your choice.
« Last Edit: April 18, 2011, 08:13:12 pm by Nephasth »
Bludgeon
  • Last login:May 18, 2011, 07:51:19 am
Re: FS: Black and Clear IL Push Buttons (Wyoming, ships)
« Reply #1 on: April 08, 2011, 04:37:04 am »
Cherry switches?
« Reply #2 on: April 08, 2011, 07:07:32 am »
The 50 gram switches are Zippy.
« Reply #3 on: April 15, 2011, 11:22:35 am »
Button Bump
DNA Dan
  • Guys.. we're not talking gold bars here
  • Last login:September 02, 2017, 11:39:00 am
« Reply #4 on: April 18, 2011, 12:19:28 pm »
I'm interested in ~half a dozen of these, but I would like to see the modification I need to do to get them to light up. Also is the light fully contained inside the button?
EDIT: Can you add anything like a label, behind the button? Is it flat in there?
« Last Edit: April 18, 2011, 12:27:12 pm by DNA Dan »
« Reply #5 on: April 18, 2011, 12:28:03 pm »
You can see the button mods I made to mine for Paradise Arcade Shop's IL-lumation RGB boards in my build thread posts #15 and #69. #15 would be the main one to get these buttons lit up, but you would have to also drill a small hole in the button body directly above the LED of the RGB board. I would mod one of these to show them lit up, but all my IL-lumination RGBs are already installed/glued into my other buttons. Hope this helps.
EDIT: Don't know off hand if it is perfectly flat on the inside, I will check when I get home this evening. My concern would be keeping the label straight/centered, it might turn inside during use if it isn't glued in place.
« Last Edit: April 18, 2011, 12:32:39 pm by Nephasth »
« Reply #6 on: April 18, 2011, 06:55:57 pm »
The inside surface of the buttons is flat, so if you wanted to you could put a label in there (I'm assuming you're thinking of using these as admin buttons). The inside diameter is 5/8", that would be as big as your label could be.
EDIT: Drilled a hole in the bottom of one and printed out a $ label and threw it together and lit it with an LED flashlight. They're kind of like a mini ring of light with a label in them. It doesn't seem that easy for the label to move once installed either, but you never know...
« Last Edit: April 18, 2011, 07:32:16 pm by Nephasth »
« Reply #7 on: April 18, 2011, 07:59:21 pm »
I LOVE your project. Any chance of me getting 16 buttons and the Run and Gun board all in one transaction?
« Reply #8 on: April 18, 2011, 08:05:46 pm »
Thank you. 16 of these buttons? Or 16 buttons like I'm using in my project? These are essentially the leftovers from making the buttons for my project. I just threw that button together and put it in one of my panels to give a good idea how these would look. If you like these (clear plungers, black bodies) I could hold you 16 of them to go with Run N Gun. But if you're talking about the original "ring of light" buttons, I don't have any spares, and to make them is EXPENSIVE as far as just buttons are concerned.
« Reply #9 on: April 18, 2011, 08:08:58 pm »
Im going to do what you did, but instead of Rings of light, I'll light up the middles.
« Reply #10 on: April 18, 2011, 08:10:50 pm »
So these will work just fine. Consider 16 on hold for you. :)
EDIT: Somewhere along the line I have also acquired a Run N Gun 2 board.
« Last Edit: April 18, 2011, 08:15:05 pm by Nephasth »
« Reply #11 on: April 18, 2011, 08:18:33 pm »
PM me a total for everything and shipping to 19711, I dunno if i have the budget for 2 boards and 16 buttons or not. RnG is listed for a lot but the last board that actually sold on ebay was $10 lol. I got pretty good feedback here/ebay/everywhere
jmike
« Reply #12 on: April 19, 2011, 06:37:11 am »
Run and Gun 2 board  :o.  Has it been tested (working?). I used to love that game. How much do you want for it? That is if Malenko doesn't take it, of course.
« Reply #13 on: April 19, 2011, 07:35:38 am »
I can live with just RnG1 if you want RnG2, Im not greedy.
Nephasth , PM me your paypal
jmike
« Reply #14 on: April 19, 2011, 11:51:31 am »
Malenko,
 You sir just made my day. (I owe you one).
Nephasth (PM sent)
Now I just need to read up on the easiest way to hook this up.
 :dizzy:
« Last Edit: April 19, 2011, 11:53:15 am by jmike »
jmike
« Reply #15 on: April 20, 2011, 07:48:54 am »
Payment sent.
« Reply #16 on: April 20, 2011, 07:50:33 am »
I'll be sending payment on friday, the money I had for this was used to bail out a relative (not literally). I can pay pal you like a $20 deposit if you'd like
« Reply #17 on: April 20, 2011, 08:05:25 am »
No need for a deposit, they'll be here whenever you're ready.
« Reply #18 on: April 29, 2011, 11:47:08 pm »
Bump. I still have 10 left.
« Reply #19 on: May 16, 2011, 04:49:01 pm »
box came today, everything is just fine already made a championship run with Salt Lake City lol
« Reply #20 on: May 16, 2011, 08:18:03 pm »
Glad to hear everything made it to you safely!
On a side note, all of the buttons are gone.
