Author Topic: Alright so tomorrow is the big day i start to build >.> one last question  (Read 2108 times)
darkmdbeener
  • Last login:May 02, 2011, 01:46:50 am
i originaly was going to put a piece of plexi or toughened glass instead of a bezel  because i was going ot have an auto rotate feature for shootem ups but that will be a while away? what should i do leave it open or add a bezel either way im going to add the auto rotate but just at a much much later date. lol outa funds XD
mgb
  • North East, US
You can always do a bezel now, made out of foam board or something and then just change it out for what you need when you add the rotate feature.
Or you can mask and spray the back side of the glass for a bezel and then scrape it off with a razor when you add the rotate.
using flat black spraypaint on the back side of glass really shines nicely through to the other side.
« Last Edit: March 11, 2011, 05:22:23 pm by mgb »
  • Last login:Yesterday at 04:57:25 pm
I'd add the bezel.  Make it look finished at least.  You can get some black matteboard for like $5 from a Michael's or A.C. Moore or some other craft store.  Just cut a hole in it for your monitor and you should be good to go.
darkmdbeener
thank you both i actually never thought about matteboard or foam board to use atm. i will make a bezel for now and chose one of thoughs
darkmdbeener
one more question ... alright a few more.
« Reply #4 on: March 11, 2011, 10:31:37 am »
So i was originally going to place vinyl artwork on the board. i know that you have to sand it first and paint it. but again funds are taped atm and friends arent finished with the art yet.
the question i am getting to is can i use laminate on it and then stick the vinyl on later or would i have to strip the laminate? can i paint it and leave it painted till i get funds for the vinyl if so would just primer do or will having primer only for a long period of time hurt the cab? also from reading the forum water based is better if applying vinyl is this correct?
milhouse
  • Last login:March 02, 2023, 08:03:32 pm
Are you using tinted glass? I have dark tint on my glass and there is no need for a bezel, if you are just trying to hide the monitor chassis.
darkmdbeener
not sure atm no more funds for something that expensive so ima just do the bezel out of something cheep before i get glass but i will look into dark tinted glass. how does that affect the image from the monitor?
milhouse
It looks great. I wouldn't even consider clear glass if I build a new cab in the future.  There is a thread above this talking about greylight, but I don't have any photos.  I can try to take a few this weekend.
I actually put together a foam bezel and used it for about a day and a half before tossing it.
