Author Topic: Stranded wire teflon or not good??  (Read 2140 times)
soyeux28
  • Last login:April 13, 2012, 12:08:51 am
« on: March 06, 2011, 09:38:11 pm »
radio shack dosnt have any wire here!!! i have found a website that sell some (around here) but i dont know nothing about wire!!
beside beeing stranded , is it a good thing or not that they are made of teflon ???
here is the description !!
1 conductor teflon wire
22awg
teflon
stranded
200 C (celcius??)
thanks for replying!
Re: Stranded wire teflon or not good??
« Reply #1 on: March 06, 2011, 10:14:25 pm »
I'd guess that the wire is copper and the insulated coating is teflon.
Stranded works, but I think solid core is easier to work with. However, if the wire will be "bending" alot (say connected to a joystick's topfire button) you'd want to use stranded. In cases where the wire will be basically stationary, I don't think it really matters.
Just about any home depot type store should sell some. I know Kneviel has found solid core "doorbell wire" at home depot that looks quite nice.
MonMotha
« Reply #2 on: March 06, 2011, 10:41:18 pm »
I generally prefer stranded when doing hookups.  It stands up to repeated flexing better and tends to hold crimps better.
The Teflon insulation is good in high temperature situations.  It can be a little difficult to work with unless you've got a rather good wire stripper.  It's also usually kinda expensive.  Probably better to just find standard PVC insulated wire.
22AWG is a good choice for general hookup in an arcade cabinet.  For power, use 18AWG.
mgb
  • North East, US
« Reply #3 on: March 06, 2011, 11:10:34 pm »
I agree, best off sticking with standard pvc insulation.
20 awg is what was typically used in real arcade cabinets (with 18awg for power conductors) but 22awg is fine.
I would definately advise against using solid conductor cable, especially a thin gauge like 24awg (used in cat 5 cable)
Thin solid gauge will very easily break over time and crimp-on connectors are not meant for solid core wire,
Though if you must use solid core wire with crimp-ons, you can also solder the connector after crimping.
Bob Roberts has wire and he is great to deal with.
http://www.therealbobroberts.net/conectas.html#wire
« Last Edit: March 06, 2011, 11:20:10 pm by mgb »
soyeux28
« Reply #4 on: March 07, 2011, 09:55:04 pm »
ok !!1 nice price from bob roberts!!!i will order from him!
1 more quick question !!!
when u say (im from quebec , and mostly speak french!! so sometime i need to clarify. Sorry about that)
18 awg for power, is it for the led (pushbutton) or for the ground (chain) or both ??
another dumb question ! on bob roberts site he says Use 18GA ....is it the same as 18 awg???
thank you for the information !
mgb
  • North East, US
« Reply #5 on: March 07, 2011, 10:40:55 pm »
Yes 18 GA is the same as 18 AWG (American Wire Gauge).
For LED power, you'll be fine with the 20 or 22 gauge wire.
When talking about power and 18awg wire for arcades, its talking more about power for actual arcade machines, such as the +5v, -5v and 12v used in arcade machines.
For Mame, you'll be fine with the 20 - 20awg cable.
soyeux28
« Reply #6 on: March 08, 2011, 08:05:07 pm »
excellent !! thank you for the reply and the help!!
