Author Topic: Visual pinball 9  (Read 3643 times)
fimbo1975
  • Last login:February 28, 2011, 08:25:59 am
Visual pinball 9
« on: February 25, 2011, 01:09:34 pm »
Hi I have installed visual pinball 9 on my computer and it works great but before I put it in my arcade cabinet I need to be able to launch visual pinball without going into the editor is there a simple way to do this?
i have read the notes on the site but cant get my head around it.
cheers
fimbo1975
Re: Visual pinball 9
« Reply #1 on: February 25, 2011, 02:05:34 pm »
Sorted it im using vpman to launch games this launches straight to roms.
cheers every one
fimbo1975
« Reply #2 on: February 25, 2011, 03:29:31 pm »
new problem all works ok but when i press esc button to quit game in mala only vpman closes down and leaves the game running in the backgroung behind the mala menu is there a way to quit vpman frontend and the pinball table at the same time?
fimbo1975
« Reply #3 on: February 26, 2011, 06:14:20 am »
Is there a way I can use visual pinball without having to go to the editor screen then i can use mala frontend to quit the game and then i wont have to use vpman.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #4 on: February 26, 2011, 08:08:33 pm »
I think it best to use the standard configuration format for the emulator. You will see the editor very quickly, minor eyesore, but all will run smoothly.
First, set it up as directed in the tutorial/how you have VP8 set up (if you do).
Second, use this 'cabinet' vpinmame dll. Rename the original in your folder to something else (for example, vpinmameo.dll), and rename the cab dll to vpinmame. Remember to reinstall it and reset your vpinmame paths.
Three, get and put closemul in your main VP directory, and point the exe path in Mala to that. (No need to click on closemul or anything. It knows what to do all by itself.)
Should be smooth as silk. (I should be this in the tutorial!)
-Banned-
fimbo1975
« Reply #5 on: February 27, 2011, 02:56:46 pm »
Right i have renamed the original vpinmame.dll to vpinmameo.dll and the download the cabinet file you told me to download and renamed it to vpinmame. do i need to add .dll to the end of this file name?
right you have told me to reset the paths to find the new file do i do this in mame setup folder under the setup paths tab.
if it is which one do i need to change is it the configuration tab or the nvram tab?
Sorry if i sound a bit slow at this but my computer skills are a bit bad but im really trying.
thanks
fimbo1975
« Reply #6 on: February 27, 2011, 05:17:29 pm »
 :banghead:
Gray_Area
  • -Banned-
  • -Banned-
« Reply #7 on: February 28, 2011, 04:15:05 pm »
thanks
1. 'MAME' and 'VPINMAME' are two different things. Vpinmame works with Visual Pinball (note the title of the thread) emulator.
2. in case 'file extensions' are displaying on your system, include the extension when re-naming. The only exception being 'shortcuts', files must have an extension.
-Banned-
