Author Topic: MAME Trackball Settings  (Read 2327 times)
methodical
  • Last login:July 05, 2012, 07:31:51 pm
« on: February 18, 2011, 01:23:48 pm »
Trackball tracks as a mouse perfectly in Windows, and the settings all seem correct but the Y Axis jumps around in game. X Axis works perfectly though. Something I'm missing?
MPH
  • Last login:May 02, 2011, 09:02:33 am
Re: MAME Trackball Settings
« Reply #1 on: February 18, 2011, 01:42:51 pm »
Just one game (which one?) or all games? Which emulator? Which version of Windows?
methodical
« Reply #2 on: February 18, 2011, 01:57:45 pm »
All Games. Latest version of MAME running on Windows 7.
milhouse
  • Last login:March 02, 2023, 08:03:32 pm
« Reply #3 on: February 18, 2011, 03:02:23 pm »
Is it smooth in Windows?
I've had this issue caused by dirty optics.
methodical
« Reply #4 on: February 18, 2011, 03:08:02 pm »
Yep, works perfectly as a mouse in windows.
tommyinajar
  • Last login:November 15, 2023, 12:23:20 pm
  • My other cab is a Cube Quest
« Reply #5 on: February 19, 2011, 02:13:23 am »
Isn't that called "backspin" or something like that by having the setting too high? Seem to semi remember that from somewhere, could be wrong...
mdoggie
  • Last login:July 22, 2012, 03:06:36 am
« Reply #6 on: February 19, 2011, 02:51:28 am »
I would, as a test, play around with the two sensitivity variables: In windows, and then in MAME. I'd probably turn it down to where it feels pretty slow in Windows, and then see if the backspin still happens in MAME. Windows, of course, doesn't use the word "sensitivity", it uses the words "cursor speed", so be aware of that. If it still does jump around too much for your taste, turn down the Y sensitivity in MAME. Start with half, and then go from there. By default in MAME, most games are at 100, so try to set it to 50.
Oh, and tabbing back and forth between Windows and MAME can cause bad stuff to happen, too. Make sure to steer clear of that. If you are using MAMEUI and not playing games in full screen, there are many issues that can happen when both Windows and MAMEUI want to use the mouse.
« Last Edit: February 19, 2011, 02:55:00 am by mdoggie »
tommyinajar
« Reply #7 on: February 19, 2011, 11:10:30 am »
Also what version of Windows are you using? I had problems with 95 that magically went away with XP. If lowering the settings doesn't help, make sure all the "windows" are on the encoder wheel, and the gut are clean.
« Reply #8 on: February 19, 2011, 11:48:24 am »
What brand trackball is it?  Most new trackballs need to be "broken in" over time for the y axis.  In Windows, you don't really notice any jumps because you're moving the trackball slowly to navigate.  But in MAME you move it a lot faster which may cause issues during the break in period.
Here's a related topic:  http://forum.arcadecontrols.com/index.php?topic=104240.0
Hope this helps!
DeLuSioNaL29
