Author Topic: First arcade restore, need some advice  (Read 3658 times)
b3dr0ck
  • Last login:January 05, 2014, 05:49:02 pm
« on: January 30, 2011, 04:07:12 pm »
I'm rebuilding a Hyperware Ultracade which is a converted Midway Mortal Combat.
Anyway, I've had a ton of technical issues, I have been working through
I've replaced the PC motherboard, the newer motherboard will not fit the case.  I can get a case, but I think it would be cleaner to mount the board to the wood back board.
What do you think?
I'd need to mount the motherboard, the HDD, the power supply and the USBLinx card.  If you'd do that, what hardware would you use?  I'm thinking some L shaped standoff brackets for the motherboard.  Not sure how I'd mount the other stuff.
Spyridon
Re: First arcade restore, need some advice
« Reply #1 on: January 31, 2011, 10:05:57 am »
If you are using a PC inside your cab, you are in the wrong forum section.
RayB
  • I'm not wearing pants! HA!
  • Last login:July 10, 2025, 01:33:58 am
  • There's my post
    • RayB.com
« Reply #2 on: January 31, 2011, 02:27:11 pm »
RESTORE verb
1. to bring back to a former, original, or normal condition, as a building, statue, or painting.
2. to reproduce or reconstruct (an ancient building, extinct animal, etc.) in the original state.
NO MORE!!
Encryptor
  • Trade Count: (+34)
« Reply #3 on: January 31, 2011, 04:12:02 pm »
Didn't the Ultracade cabs come with a pc from the factory? If so and he is restoring back to original then there should be a pc in it and he is restoring it to factory original condition.
Encryptor
Spyridon
« Reply #4 on: January 31, 2011, 08:55:49 pm »
But I don't think they were shipped from the factory in Midway cabs.
Encryptor
« Reply #5 on: January 31, 2011, 10:20:29 pm »
I took his post to mean the Ultracade cab had been converted to a Mortal Combat but maybe you're correct.
Encryptor
mekishiko
  • Last login:May 30, 2011, 09:12:57 pm
« Reply #6 on: January 31, 2011, 11:48:11 pm »
Yeah I ran into an old Final Fight USA style Cab that was modified to an Ultracade with the multigame PC inside of it at a pizza shop. It was well done but still a little odd. I'd imagine it'd be hard to discern a re-used cab if you didn't have experience with them.
