Author Topic: StartCom for Mala  (Read 8189 times)
  • Moderator
  • Last login:January 06, 2026, 11:02:04 am
StartCom for Mala
« on: January 26, 2011, 06:48:34 pm »
With the undying help of Loadman, we created a mala plug-in that works great with MRotate.
It starts MRotate, and tells it which way to turn the monitor, based on the games' original orientation.
This plug-in can work with other command line motor programs, but it was designed with MRotate in mind.
If you have a rotating monitor project, and you are using Mala, then add StartCom to your list of must-haves.
StartCom can be downloaded from the Mala website:
http://malafe.net/index.php?page=plugins
Here is a link to the thread we kept while developing it, again, bear with the length of the thread, a lot of info was posted.
http://forum.arcadecontrols.com/index.php?topic=91842.0
  • Moderator
Re: StartCom for Mala
« Reply #1 on: June 08, 2011, 06:22:24 pm »
Here is a helpful post by Topjimmycooks over in the Mala forum, about using bat files to control rotating software other than Mrotate from startcom.
http://forum.arcadecontrols.com/index.php?topic=112254.0
