Author Topic: Question about wheels on a cab  (Read 1587 times)
Hituro
  • Last login:September 04, 2016, 01:12:43 am
« on: January 05, 2011, 07:31:53 am »
So, don't know if this belongs in this forum, but I'll post anyway.
So, some of you may know from previous posts, but I have a cab kit that I purchased from Mameroom.  I have made mods to it, one of them being that I put wheels on the bottom.  Now, the design on the cab has it so that the bottom board is raised up a couple inches or so from the sides of the cab.  The cab is designed for the sides to just sit on the floor.  But it's a heavy mother, and moving it is difficult, hence the addition of the wheel.  One problem though, on the front of the cab, the bottom board is only attached by 2 cam-locks.  One on each side, where as the back has 3 on each side to hold the back.  This doesn't make much sense to me, seeing as how most of the weight due to the control panel, and people leaning on the control panel, is more on the front end of the cab.  Because of this and gravity, the front cams on the bottom board on my cab snapped in half.  I replaced the board, and no real damage was done aside from the steel cams being snapped clean in half.  But my question now comes into play.  I still want to keep wheels on the thing.  Now, if I add more support, via L-Brackets, to add more support between the sides and the bottom, will this solve my problem?  I was thinking of using bolts, and the brackets, along with the cam locks to add more support.  (thinking maybe 5 brackets on each side of the cab).  Will this add the needed support?  or will this same problem repeat itself?  The only other thing I can think of, is attaching a large board to the bottom covering the whole base, and then adding the wheels to that, but screwing them into the sides, but I just don't like how it would look, and it would make my cab much too tall.  So, I know it's long winded, but will bolting the base and the sides with many brackets keep it together this run?
Hituro
Re: Question about wheels on a cab
« Reply #1 on: January 05, 2011, 05:58:53 pm »
still no answer :(
Donkbaca
    • Slim built MAME/Xbox cab
« Reply #2 on: January 05, 2011, 06:03:03 pm »
A silly question:  Why do you need wheels?  Are you going to move it a lot?
I think the brackets thing should work ok, might even be a bit overkill.
bkenobi
« Reply #3 on: January 05, 2011, 06:12:27 pm »
Post pictures.  I'm not quite sure what the problem you are describing looks like.
Hituro
« Reply #4 on: January 05, 2011, 06:20:28 pm »
The only time I move it, is to get to the back to do any maintainence.  And it's much easier to do that, by pushing it on wheels.  I know it might be silly to some, but being able to move it easily, makes accessing it easier too.
Hituro
« Reply #5 on: January 05, 2011, 06:21:07 pm »
That might be hard at the moment... I disassembled the cab for modifications
Donkbaca
« Reply #6 on: January 05, 2011, 06:30:39 pm »
http://cgi.ebay.com/Cabinet-Wheel-Assembly-happ-MAME-/390241133410?pt=LH_DefaultDomain_0&hash=item5adc2f2362
how about just putting two of these in the back?  THen you just tilt it when you have to move it.
bkenobi
« Reply #7 on: January 05, 2011, 09:16:28 pm »
I just installed these on my cab.  They screw directly into the threads where the original casters went.
http://www.lowes.com/pd_235514-255-4031299NN_0__?productId=3026956
