Author Topic: software/hardware able to produce vertical refresh other than 60Hz?  (Read 1695 times)
abaraba
  • ---Perm Ban---
  • Last login:July 30, 2011, 08:42:58 am
I know VAntAGE has fantastic built in menu to set up arbitrary refresh rate. I know DOS TSRs can turn PC resolutions of ordinary VGA cards into 15kHz compatible signal, and I know AdvanceMAME (AdvanceCAB) has few such tools too. What I do not know is if there is anything beside VAntAGE that can output the whole range, covering not just 50Hz and 60Hz, but also everything in between.
* Moon Patrol @ 57Hz - is AdvanceMAME supposed to generate some resolution @ 57Hz, or is it only concerned with aspect ratio and all resolutions are always exactly @ 60Hz (50Hz)?
* Is mainstream MAME, DOS or Win, able to produce resolutions with refresh rates other than 60Hz?
* Is ArcadeVGA able to produce resolutions with refresh rates other than 60Hz?
* Is "soft15kHz" able to produce resolutions with refresh rates other than 60Hz?
...or, in short:
- What software/hardware is able to produce vertical refresh other than 60Hz?
Btw, why option "-monitor pal" in MAME has resolutions @ 57Hz instead of 50Hz?
« Last Edit: January 03, 2011, 05:34:35 am by abaraba »
---Perm Ban, again---
Gray_Area
  • -Banned-
  • -Banned-
Re: software/hardware able to produce vertical refresh other than 60Hz?
« Reply #1 on: January 04, 2011, 12:36:10 am »
Powerstrip. Prepare to do a lot of reading before asking more questions.
-Banned-
abaraba
  • ---Perm Ban---
« Reply #2 on: January 04, 2011, 03:20:58 am »
Why would anyone use 'Powerstrip' instead of 'AdvanceMAME' for DOS/Linux and 'Soft15kHz' for Windows?
So, mainstream MAME is still not able to emulate authentic resolutions/refresh rates?
Gray_Area
  • -Banned-
  • -Banned-
« Reply #3 on: January 07, 2011, 02:03:14 am »
MAME does what the video drivers tell it to do, which are at the system level. To access the video drivers, you need things like mentioned above.
-Banned-
