Author Topic: Speaker interference from jukebox page turning  (Read 2878 times)
gms1975
  • Last login:August 30, 2022, 09:45:05 am
« on: December 19, 2010, 02:42:22 pm »
I am having an issue with interference from my  in-wall speaker mounted about two inches to the left of my wall mount jukebox.  When you turn the title pages, the motor apparently gives interference to that speaker.  It happens only for a second each time you turn the page. You can hear a burst of static.  I can't move the speakers due to the location of the jukebox.  Does anybody know if there is a way to shield the speaker from the interference?
BobA
  • What Me Worry?
Re: Speaker interference from jukebox page turning
« Reply #1 on: December 19, 2010, 06:15:47 pm »
You might try shielding the wire going to the speakers before trying to shied the whole speakers.   Depending on where the motors get their power there maybe some other noise filtering issues.
« Last Edit: December 19, 2010, 06:17:54 pm by BobA »
gms1975
« Reply #2 on: December 19, 2010, 10:14:22 pm »
What would you suggest for shielding the wire?
BobA
  • What Me Worry?
« Reply #3 on: December 20, 2010, 09:03:33 am »
I would replace the wire with shielded wire that is made for the purpose but I would think that in foil strips wrapped around the wire with a bare copper wire on the outside that you can ground might serve for test purposes.
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
« Reply #4 on: January 04, 2011, 07:21:41 am »
Hello,
What is the make of the wallbox?
Regards
Alan Hood
ami-man
UK
