Author Topic: Help hacking a Roadblasters CP  (Read 2496 times)
« on: December 13, 2010, 09:40:26 pm »
I picked up a RoadBlasters CP off eBay.  It is one of my "grails" and I've not been able to find a satisfactory way to play it in MAME.  I also purchased an Opti-Wiz from GGG so I can connect it to my PC.   I'm looking for some advice for hooking this up from someone who has done it and/or is smarter than me.
Here are my assumptions -
Buttons -
Large Green Wire - Ground for buttons
Large Black Wires - Trigger and Special Weapons buttons
Optical Hook-up
Red = 5v power
Black = Ground
Blue=?
Purple=?
I'm assuming that the Blue or Purple are for the X-axis.
Any guidance or suggestions would be appreciated.  I've searched and not been able to find any specific information.
Re: Help hacking a Roadblasters CP
« Reply #1 on: December 14, 2010, 01:40:07 pm »
I found this by accident -
http://www.thisoldgame.com/products/usb-adaptor-for-atari-yoke-controller
Anybody have experience with this adapter?
bkenobi
« Reply #2 on: December 14, 2010, 04:04:26 pm »
That yoke adapter cable is not what you want.  That is for a Star Wars controller (maybe others too).  What you have is a standard Atari steering wheel board.  I don't remember which is which, but there's power, ground and a signal wire.  There should be a writeup here about hacking a pole position or some other Atari steering wheel.
huygens
  • Last login:October 31, 2011, 01:33:08 am
« Reply #3 on: December 14, 2010, 04:19:17 pm »
The blue and purple wires from the optic board are the quadrature signals. They should be hooked up to Xa and Xb on the opti-wiz (you need both connected). If the mouse moves in the wrong direction just reverse them.
« Reply #4 on: December 14, 2010, 04:27:57 pm »
I thought the same thing but the item description specifically mentions RB and the molex connector looks about the same.  Not sure I'd want to risk $60 on it unless someone could tell me for sure it worked.  Thanks for the reply.
« Reply #5 on: December 14, 2010, 04:29:07 pm »
Thanks!  I didn't realize both needed to be connected which was confusing.
bkenobi
« Reply #6 on: December 14, 2010, 05:39:15 pm »
Trust me, those connectors are not the same.  If they are, then the photo is wrong.  The Molex connector in the yoke adapter picture is a set of 9 pins that are mostly round (except for the keyed pin).  The connector on your steering wheel is a 4 pin inline connector more similar to what you'd see on a PC (0.1" spacing or there abouts).
« Reply #7 on: December 15, 2010, 09:08:02 am »
I didn't get a chance to hook it up last night but I did spend some time hacking apart power cables from an old PC.  Looks like they will work great to connect to the RB CP.
tommyinajar
  • Last login:November 15, 2023, 12:23:20 pm
  • My other cab is a Cube Quest
« Reply #8 on: December 15, 2010, 08:24:51 pm »
Anyone hack buttons into a non Roadblaster wheel (I.E. Road Riot wheel = No top fire buttons)
