Author Topic: 32/64bit Groovy Arcade Linux LiveCD/Install  (Read 146027 times)
NightSprinter
  • Last login:June 17, 2018, 08:59:56 pm
Re: 32/64bit Groovy Arcade Linux LiveCD/Install
« Reply #280 on: August 26, 2013, 01:52:50 pm »
Excellent.  I'll give it a shot tomorrow after work.  (My shift setup today ends at 11:30 and going back in tomorrow morning at 9:45.)  This could be a major step in progression towards the next version of GroovyArcade
It doesn't matter how bad things are, it'll work out in the end.
NightSprinter
« Reply #281 on: August 30, 2013, 11:22:06 am »
So, got the system fully updated, re-compiled 7.2 of the ATI driver for X, and now am experiencing several oddities.  The first of which, I seem to lose my mouse cursor when X starts up.  Next, some games seem to work just fine while others do not.  For example, I can run all of my confirmed working Neo-Geo roms (Double Dragon, Magician Lord, etc) and a select few other games (Street Fighter II) just fine.  Others exit immediately with the same problem about XRandR.  If you want, I can log on temporarily from the linux box and post some logs.
I forgot to ask, would any of the SDL patches to the ISO have had anything to do with this as well?
[Edit] Ah-HA!  It IS in fact SDL being un-patched that is causing my issues.  I did an environment variable of SDL_VIDEO_X11_XRANDR=0, and got no issues (but no full-screen switching).  So apparently SDL in some way needs additional patching for such low resolutions.
« Last Edit: August 30, 2013, 01:26:07 pm by NightSprinter »
Ansa89
  • Last login:December 09, 2016, 10:40:11 am
« Reply #282 on: September 03, 2013, 02:45:23 am »
Update 15KHz patches for linux 3.11.
Earth could be the hell of another world
NightSprinter
« Reply #283 on: September 03, 2013, 08:17:44 am »
Will test tonight.
Monkee
  • Last login:March 27, 2018, 09:37:30 am
« Reply #284 on: September 15, 2013, 04:06:08 pm »
Hi,
I'm planning on buying a tri-frequencies cabinet and I was wondering if Groovy Arcade can take advantage of that for 24 and 31khz games ?
Thanks,
Monkee
NightSprinter
« Reply #285 on: September 17, 2013, 05:54:48 pm »
Yes, it can.  If you have the manual for the monitor, you can enter everything needed for SwitchRes and GroovyMAME/GroovyUME after installation.  There is a chance the D9200 or D9800 presets could work for you as well.
Monkee
« Reply #286 on: September 28, 2013, 01:37:49 pm »
Thank you NightSprinter !
« Last Edit: September 28, 2013, 06:14:12 pm by Monkee »
Ansa89
« Reply #287 on: November 04, 2013, 09:03:30 am »
Update 15KHz patches for linux 3.12.
jtslade
  • Last login:April 24, 2024, 08:02:12 pm
  • Keep it looking originallish!
« Reply #288 on: December 30, 2013, 01:36:39 pm »
So just got this setup via USB boot on my cocktail vertical only project.
Its being output to an Elctrohome G07 (via Gigabyte mobo with AMD Hybrid onboard VGA) run through a Ultimarc JPAC
How do I define or select the resolution that will run native for the AdvanceMenu? Where is this located ?
Thank you!
Ms. Pacman Original Cocktail with Non destructive mod to Groovy Arcade Linux with All 4way Vertical Cocktail capable 2 button or less games.
Neo Geo MVS Mame Cab Running Hyperspin, 25" Nanao Arcade Monitor, Mini-pac, ATI Radeon HD 4850 (ATOM-15), IL 8 Way Euro-Sticks from Paradise Arcade, Win XP 64bit, and tons of other junk.
jtslade
« Reply #289 on: January 05, 2014, 02:28:43 am »
Bump
Ansa89
« Reply #290 on: January 06, 2014, 04:09:18 am »
jtslade, try to ask there.
duke_of_earl
  • Last login:February 06, 2014, 05:10:24 am
« Reply #291 on: January 10, 2014, 02:55:32 pm »
I am also interested in the resolution change of AdvanceMenuPLUS. As far as I know, the resolution is fixed to be 648x480. To change that, you would need to modify the file /etc/X11/xorg.conf and change the section "Modes". This is what i did to set the resolution to 320x240:
Section "Modes"
        Identifier      "ArcadeModes"
#  648x480@60.00 15.6300Khz
#       ModeLine          "648x480x60.00" 13.129200 648 672 736 840 480 482 487 521 -HSync -VSync interlace
        ModeLine          "320x240@57.0Hz" 6.440 320 328 360 408 240 249 252 277 -hsync -vsync
EndSection
Note that I had to find a modeline configuration that worked with my arcade monitor. I also had to make changes to the AdvmenuPlus theme, that was configured for the default resolution.
jtslade
« Reply #292 on: January 16, 2014, 02:29:48 pm »
What kind of arcade monitor do you have that you enabled the lower res menu resolution for?
Ansa89
« Reply #293 on: January 21, 2014, 09:04:16 am »
Update 15KHz patches for linux 3.13.
offset
  • Last login:May 12, 2024, 07:04:08 am
« Reply #294 on: February 02, 2014, 10:34:29 am »
Thinking of using GroovyArcade for an older computer that I have laying around (with an AGP ATI Rage 128 videocard) that I have to use with a Wells Gardner arcade monitor (through a J-PAC).
Where is the current source tree and build scripts?  The GIT repo mentioned at https://code.google.com/p/groovyarcade/source/checkout appears to be empty.
Ansa89
« Reply #295 on: February 03, 2014, 03:01:36 am »
offset, try to ask here.
jtslade
« Reply #296 on: February 09, 2014, 11:04:05 am »
So what are my options to get the Marquee's to fill the screen. Do I need to resize them all in Photoshop or can I set some scaling options?
« Last Edit: February 09, 2014, 11:11:10 am by jtslade »
Ansa89
« Reply #297 on: March 31, 2014, 04:00:31 am »
Update 15KHz patches for linux 3.14.
Ansa89
« Reply #298 on: June 09, 2014, 06:17:07 am »
Update 15KHz patches for linux 3.15.
Ansa89
« Reply #299 on: August 19, 2014, 03:32:21 pm »
Update 15KHz patches for linux 3.16.
cools
  • Last login:March 11, 2024, 02:59:06 pm
  • Arcade Otaku Sysadmin
    • Arcade Otaku
« Reply #300 on: August 19, 2014, 04:09:41 pm »
Thank you!
Ansa89
« Reply #301 on: October 10, 2014, 05:26:22 am »
Update 15KHz patches for linux 3.17.
ozfalcon
  • Last login:April 07, 2022, 04:55:03 am
  • ZSystem
« Reply #302 on: October 19, 2014, 08:19:57 pm »
Anyone using Xorg v1.16 finding any difference in performance to Xorg v1.15?
I am finding glxgears to run very slow in fullscreen with v1.16 (1024x768@75hz).
Note: I'm just checking out vanilla Xorg v1.16, No patches or changes at this time.
« Last Edit: October 19, 2014, 08:25:34 pm by ozfalcon »
Ansa89
« Reply #303 on: December 11, 2014, 12:50:07 pm »
Update 15KHz patches for linux 3.18.
Ansa89
« Reply #304 on: February 25, 2015, 04:04:22 am »
Update 15KHz patches for linux 3.19.
jtslade
« Reply #305 on: April 19, 2015, 10:10:30 pm »
Anyone know how to change the advance menu resolution... It would be great to run it at an arcade res
jtslade
« Reply #306 on: April 22, 2015, 08:38:47 pm »
Config
DoogyRev
  • Last login:July 04, 2019, 08:24:49 am
« Reply #307 on: November 18, 2015, 02:32:33 pm »
Is there a similar patch for 4.12 kernel?
philenotfound
  • Last login:May 28, 2019, 10:36:33 am
« Reply #308 on: November 19, 2015, 03:55:28 am »
Which version do you really want? I suspect 4.12 is a typo, there is no 4.12 yet ;)
DoogyRev
« Reply #309 on: November 19, 2015, 02:45:13 pm »
Hehe. Sorry, I meant 4.1.12
It's only the linux diff I need. The 3.19 one fails patching the second last file because it doesn't seem to exist.
« Last Edit: November 19, 2015, 03:02:59 pm by DoogyRev »
philenotfound
« Reply #310 on: November 20, 2015, 05:33:30 am »
I only did it on 4.1.13 but the same patches should apply on 4.1.12
You can find the patches here:
https://github.com/philenotfound/linux-stable-15khz/tree/4.1.13-15khz
Or a tarball here:
https://github.com/philenotfound/linux-stable-15khz/releases/tag/v4.1.13-15khz
DoogyRev
« Reply #311 on: November 20, 2015, 01:03:00 pm »
How did you do it? Did you just patch the linux-3.19.diff onto your 4.1.13 kernel source or did it need tweaking?
philenotfound
« Reply #312 on: November 21, 2015, 06:00:39 pm »
If they needed tweaking, I updated the commit message to reflect this. The linux-patch needed tweaking for 4.1. The other 2 didn't since 3.19.
Basically upon a new tag in linux-stable I create a branch <version>-15khz, cherry-pick the patches from an older one, tweak if necessary and tag them as v<version>-15khz.
On a semi-regular basis I redo this to have an up-to-date kernel on my cabinet.
DoogyRev
« Reply #313 on: November 22, 2015, 03:03:48 pm »
Thanks, I have it working now. I needed it to use the console on my non Groovy Arcade Linux installation. I know how the offsets in the diff file work now so I should be able to sort it myself if it changes again.
Ansa89
« Reply #314 on: July 27, 2016, 09:23:44 am »
Now you can find updated linux kernel patches here.
