Author Topic: 32/64bit Groovy Arcade Linux LiveCD/Install  (Read 146375 times)
ves
  • Last login:April 11, 2020, 02:57:49 am
Re: 32/64bit Groovy Arcade Linux LiveCD/Install
« Reply #240 on: March 26, 2012, 09:15:40 am »
Thank alsa89
Hunk_4TH
  • Last login:Yesterday at 04:22:23 pm
  • I DON'T ALLOW VANDALISM IN MY STOOOOOOOOOOORE!
« Reply #241 on: May 08, 2012, 08:28:08 pm »
Is there a new link for this? The site seems down.
Ansa89
  • Last login:December 09, 2016, 10:40:11 am
« Reply #242 on: May 22, 2012, 01:11:40 pm »
15KHz patches updated for linux 3.4.
Earth could be the hell of another world
sirwoogie
  • Supreme Chancellor
  • Last login:April 12, 2024, 10:16:38 pm
  • It's Hollyfeld in a Winnebago!
« Reply #243 on: July 05, 2012, 12:30:38 am »
Any news on the original site and content? If this site can't be hosted anymore, I'm sure we can take an archive of the last snapshot and make it available. However, I cannot seem to find reliable sources to get the ISO nor latest site content (archive.org has it back to July 2011 as the latest).
Ansa89
« Reply #244 on: July 05, 2012, 02:17:02 am »
I have the latest snapshot from git (I got it before the official site being closed).
If you are interested I can try to compress and upload it somewhere.
sirwoogie
« Reply #245 on: July 05, 2012, 09:58:56 am »
that would be great. Let me know how bit it is and we'll find a spot. i also noticed on the git that the ISO's are still there, so that is good. I may get those down as well.
Ansa89
« Reply #246 on: July 05, 2012, 10:09:37 am »
I checked the content of my cloned branch: it's the development directory without isos (just source/scripts to create the iso).
The checkout url was "git://git.groovy.org/groovy/groovyarcade.git".
If you still interested, the compressed archive is 21MB :) .
  • Last login:June 10, 2024, 07:56:16 am
« Reply #247 on: July 05, 2012, 11:38:18 am »
The original site's git is available for download from the new site: http://code.google.com/p/groovyarcade/downloads/detail?name=groovyarcade.tbz2&can=2&q=
sirwoogie
« Reply #248 on: July 05, 2012, 01:46:45 pm »
yeah, I saw that after I posted. Around here we like to keep sites around for posterity and archival. So whatever people got, we'll take it. :)
Ansa89
« Reply #249 on: July 05, 2012, 02:08:39 pm »
« Reply #250 on: July 05, 2012, 02:31:37 pm »
Sounds great, thanks :)
Ansa89
« Reply #251 on: July 23, 2012, 04:35:32 am »
Update 15KHz patches for linux 3.5.
EDIT: patch reuploaded (there was a stupid "wrong variable name" error). This one should be good.
« Last Edit: July 24, 2012, 12:28:03 pm by Ansa89 »
dapsaille
  • Last login:July 13, 2019, 01:31:26 am
« Reply #252 on: August 15, 2012, 11:44:55 am »
Thanks for this patch ...
 If i understand well this patch will permit 15khz with kms ati driver ?
 I'm building my own gentoo 64bits distro with this patch and switchres, is there is other patches for make a 'groovymame' clone (emerge-webrsyncing in a vm for now, so not tested ^^ ) ?
Ansa89
« Reply #253 on: October 01, 2012, 05:47:52 am »
Yes, this patch is needed to correctly show the tty on a 15KHz monitor.
Without the patch you can only start a X server (with custom modeline) to see something.
Ansa89
« Reply #254 on: October 01, 2012, 05:51:27 am »
Update 15KHz patches for linux 3.6.
federillo67
  • Last login:December 11, 2012, 06:33:19 pm
Vertical orientation counter clockwise
« Reply #255 on: December 02, 2012, 08:19:06 am »
Hi all.
In my cab i have a 15khz arcade monitor mounted in vertical position.
If i choose "vertical" in monitor GroovyArcade setup, the image is perfect but turned upside down (rotated clockwise from horizontal).
What should i do to rotate image counterclockwise instead of clockwise ?
Thanks in advance !
You're great !!!  :D
Re: Vertical orientation counter clockwise
« Reply #256 on: December 03, 2012, 11:47:42 am »
Hi all.
Thanks in advance !
You're great !!!  :D
Use these two options combined: -flipx -flipy
federillo67
« Reply #257 on: December 03, 2012, 04:20:48 pm »
Yes! Flipx+flipy together did the trick!  :notworthy:
Games work well and the aspect is fine.
Now i have a problem with frontend. :embarassed:
I can't succeed in correctly rotating wahcade layout (if i try "xrandr -o left" before launchingwahcade, wahcade layout is rotated, but then games are miscentered and often playing too fast... ???)
I am trying wahcade because advancemenu always throws "illegal instruction" as for other guys in the forum...
federillo67
« Reply #258 on: December 05, 2012, 05:42:50 am »
Hi all.
I have dropped wahcade and returned to advancemenu.
I downloaded latest version (27-11) sources from http://arcadeforever.forumfree.it/?t=64108705 and just compiled (./configure + make).
Now Advancemenu works fine! :D
« Reply #259 on: December 05, 2012, 06:26:17 am »
Hi all.
Hi federillo67,
That's good to know. Can you tell as what exact version of AdvMenu was throwing the "illegal instruction"? Does the problem still occur with the current binaries on the arcadeforever site?
federillo67
« Reply #260 on: December 05, 2012, 07:22:00 am »
Hi Calamity.
Faulting advmenup is from GroovyArcade CD.
version is: AdvMenuPLUS alpha-20111221 (Compiled Jun 5 2012 with gcc-4.7.0) from --version parameter.
The binaries downloaded from Arcadeforever site (advmenup-20121127-ubuntu32.tar) give me the following error:
./advmenup: error while loading shared libraries: libvga.so.1: cannot open shared object file: No such file or directory
maybe because they are compiled on Ubuntu.
Trying to compile from sources seemed to me the fastest way, more then trying to install libvga (This one would have been my second choice... :)).
Thanks for your work on Groovy Arcade ! :notworthy:
Ansa89
« Reply #261 on: December 11, 2012, 05:21:11 am »
Update 15KHz patches for linux 3.7.
demetris
  • Last login:March 04, 2013, 07:15:50 am
« Reply #262 on: December 18, 2012, 11:40:24 am »
Thanks man. Work welldone :)
Ansa89
« Reply #263 on: February 19, 2013, 08:15:52 am »
Update 15KHz patches for linux 3.8.
NEWS: now it's also possible to start at 25KHz instead 15KHz.
To do so, you need to replace the "c" parameter that you find at the end of "video=VGA-1:640x480ec" with "z".
Example:
- string to be added to lilo/grub to boot at 15KHz -->  "video=VGA-1:640x480ec"
- string to be added to lilo/grub to boot at 25KHz -->  "video=VGA-1:640x480ez"
Keep in mind that this new feature is experimental and could not work.
NightSprinter
  • Last login:June 17, 2018, 08:59:56 pm
« Reply #264 on: February 19, 2013, 10:35:50 am »
Nice.  Gonna try it in this Mint 14 install (yeah, I'm playing with multiple distros) and see how GRUB2 likes it.
It doesn't matter how bad things are, it'll work out in the end.
NightSprinter
« Reply #265 on: February 20, 2013, 03:49:50 pm »
Still having issues, but would you know if that video addition to the kernel line would work in GRUB2 as well?
Ansa89
« Reply #266 on: February 20, 2013, 03:56:14 pm »
It should work also on grub2, since it is a kernel parameter and not a grub related thing.
NightSprinter
« Reply #267 on: February 21, 2013, 11:17:39 am »
Yup, it finally worked (though I had to save the default kernel source's config file and load it into the 3.8 sources so it could finally boot).  I've got it booting on Fedora 18 with a 720x480 15KHz console.  Once I get home tonight from work, I just need to figure out the "bad parameter" error I'm getting again from switchres.  Another semi-related issue is with certain native/wine games locking up the display.  I might have Calamity look into that as well, as it happened with modelines generated from SwitchRes.
« Last Edit: February 21, 2013, 11:25:52 am by NightSprinter »
Ansa89
« Reply #268 on: April 29, 2013, 05:27:45 am »
Update 15KHz patches for linux 3.9.
NightSprinter
« Reply #269 on: May 02, 2013, 11:00:37 am »
Thanks greatly for the 3.9 patch.  Not only did it patch correctly on the first attempt, but it boots wonderfully with a 15KHz console and native linux games running at proper arcade resolutions.  I'm curious, though, what are your thoughts on the new Intel HD5000 graphics series for GroovyUME and native linux gaming on arcade monitors?
Ansa89
« Reply #270 on: May 03, 2013, 02:43:58 am »
I don't know if the Intel graphics is suitable for arcade games.
I have only one setup to test the arcade stuff and comes with an ATI Radeon HD5450; so any test will be appreciated.
NightSprinter
« Reply #271 on: May 05, 2013, 11:07:31 am »
I could look into it when the time comes.  I can say after testing in Ubuntu with the patched kernel, that something else will most likely need patching (not sure if it's SDL, or the Xorg ATI driver, or both) in order to get GroovyMAME and GroovyUME to automatically create and switch resolutions.
NightSprinter
« Reply #272 on: May 15, 2013, 12:46:42 am »
Got it re-installed and working fine now (save for the modeline thing, but I believe that could be specific to Rom Check Fail.).  Just out of curiosity, how can one utilize the config files in /etc/cwiid/wminput for different situations?  Like, for example, I want to use the gamepad configuration for consoles and games that support joystick input and lightgun for lightgun titles in emulators.  I've tried using wminput -c /etc/cwiid/wminput/gamepad to no positive result.  Not entering something correctly, I'm guessing?
Ansa89
« Reply #273 on: July 01, 2013, 04:59:32 am »
Update 15KHz patches for linux 3.10.
NightSprinter
« Reply #274 on: August 14, 2013, 10:02:31 pm »
Ansa89, has any progress been made on Kernel 3.11?  Not sure if xf86-video-ati would need upgrading to benefit from it, but I know the latest open source drivers for the radeon cards has brought massive 3D improvements to a number of cards from the 4000 series and up  Just curious about that.
[Edit] Nevermind, I derped pretty badly before checking out the Kernel website.  3.11 is stil in RC phase.  Don't mind me.  :P
« Last Edit: August 17, 2013, 08:58:55 am by NightSprinter »
NightSprinter
« Reply #275 on: August 18, 2013, 12:06:30 pm »
This is strange, attempting to patch xf86-video-ati sources with the allow_low_res.diff file results in "HUNK #1 failed" at what may be lines 1389 and 3182 in the respective files ./src/drmmode_display.c and ./src/radeon_driver.c
Could there be a possibility this patch file  may be out of date for recent versions?  I would be more than willing to break my Arch install once again to test a low-res patch for X.Org version 7.2.
Ansa89
« Reply #276 on: August 25, 2013, 12:31:31 pm »
The "allow_low_res.diff" patch was made for pretty old xf86-video-ati drivers.
I will try to update the patch for newer version ASAP.
NightSprinter
« Reply #277 on: August 25, 2013, 05:26:18 pm »
Ah, ok.  How would this affect x.org and the XRandR extension?  Hasn't it changed the format of modelines recently when it went from 1.1 to the latest versions?
Ansa89
« Reply #278 on: August 26, 2013, 06:37:08 am »
The patch doesn't affect xorg and/or xrandr; it simply tell the ati driver to accept very low resolutions (the lowest was 320x200 and becomes 160x100).
Ansa89
« Reply #279 on: August 26, 2013, 06:49:51 am »
Here is the new "low-res" patch for xf86-video-ati 7.2.0 (the old one still there).
