Author Topic: USB hard drive... is it ok to run your gaming and frontend off it?  (Read 4304 times)
nickynooch
  • Last login:August 29, 2020, 02:54:00 am
« Last Edit: May 07, 2020, 02:49:20 pm by nickynooch »
ahofle
    • Arcade Ambience Project
Re: USB hard drive... is it ok to run your gaming and frontend off it?
« Reply #1 on: November 23, 2010, 03:22:07 pm »
It works just fine.
garnerb350
    • Hyperspin
« Reply #2 on: November 23, 2010, 03:28:08 pm »
+1
No problem at all... I have all my stuff located on my TB drive and I did a backup and ran Hyperspin from the TB...works fine...
nickynooch
« Reply #3 on: November 23, 2010, 03:47:06 pm »
Awesome!
« Last Edit: May 07, 2020, 02:47:56 pm by nickynooch »
WhereEaglesDare
    • My HomePage
« Reply #4 on: November 23, 2010, 10:32:19 pm »
what happens if you change it to another pc and your external HDDs designator is different than the one you used to program it?
bkenobi
« Reply #5 on: November 24, 2010, 01:24:51 am »
Depends on the FE, but some won't work.  GameEx, for instance, has registry entries that the author has indicated won't allow you to switch (easily anyway) to a different PC.  It's not a copy protection thing, it's basically due to how Windows works.  If the FE doesn't have registry entries, I'm sure it would work great!
WhereEaglesDare
    • My HomePage
« Reply #6 on: November 24, 2010, 07:29:27 am »
but lets say that your drive is drive E on one PC and drive G on another... what then?
garnerb350
    • Hyperspin
« Reply #7 on: November 24, 2010, 08:29:33 am »
I know where Eagles getting at... (i think)
My TB was listed as Drive D for a while and then when i switched PCs...it was then H... I had to go in and redirect my locations of everything as per my emulators and frontend...(mame snaps,ctrlr,artwork etc) Pain in the arse...Happened everytime I switched to different PCs...but then I found out (did a search) and there is a feature where you can assign drive letters to different drives...via control panel through Windows... I assigned the TBdrive from H back to D.... and it runs ok...as long as locations are correctly listed...
severdhed
  • RIP Dinosaur Hippo
« Reply #8 on: November 24, 2010, 10:59:19 am »
if your drive letter changes, right click on my computer,click manage.  choose Disk management.  find your external drive, right click and choose change drive letter
Havok
  • Trade Count: (+17)
  • Last login:August 18, 2025, 12:44:57 am
« Reply #9 on: November 24, 2010, 11:17:49 am »
That's it - of course you may need to shuffle disk drive letters around to get what you want, which can break other software.
AtomicFE uses relative paths, so would be unaffected by a drive letter change...
garnerb350
    • Hyperspin
« Reply #10 on: November 24, 2010, 01:16:48 pm »
+1 severdhed
That was what i was mentioning (couldnt remember exactly)
Now on my setup, I had C: (40gig) D:&E: (CD/DVD drives) F:(TB drive) G&H:( USB drives)
Now on my TB, I have my emulators, frontend, jukebox mp3 etc, and other various files...
Currently (because I am lazy) i have a copy of my front end that i use primary on the C Drive that i havent taken off... As long as my locations are correct, it runs fine... Incase the pc by some reason dies...all i have to do is switch the TB to another PC and like said before make sure the locations are correct...
  • Last login:June 25, 2025, 03:09:16 pm
« Reply #11 on: November 24, 2010, 03:09:40 pm »
I would think the easiest setup would be up all software, emulators, FE's on the dedicated C drive.
All roms, chds, music, snaps, and other large files can go on a USB TB drive. The C drive should be less than a few gb and would be much easier to backup.
Granted, that would be a setup if using a USB TB drive was planned from day 1.
