Author Topic: starting an application with Mala  (Read 2894 times)
raungst
  • Last login:October 14, 2016, 03:05:40 pm
« on: November 19, 2010, 06:24:59 pm »
I'm working on adding two gamepads to my cab. I have MaLa set as the shell. I need to be able to run Xpadder on startup, so that the joystick buttons are turned into keypresses. Is there a way for Mala to run a program when it starts up, even when shelled?
Neverending Project
    • Arcade Fixer
raungst
Re: starting an application with Mala
« Reply #2 on: November 20, 2010, 11:53:47 am »
I saw this, but it doesn't seem to work when you have MaLa as a shell. It works great if I launch Mala from explorer, but doesn't actually launch Xpadder if MaLa is the shell. There was another post about turning a batch file into an exe file and then using that as the shell, so I guess I'll try that next.
raungst
« Reply #3 on: November 20, 2010, 02:35:30 pm »
This is my fault. The plugin works. I was shelling a different version of MaLa than I had put the plugin in.
Now... Is there a way to have it start so it's minimized?
Gray_Area
  • -Banned-
  • -Banned-
« Reply #4 on: November 22, 2010, 03:53:09 pm »
If it is like a shortcut, then right-click > properties > shortcut > run - select 'minimized'.
-Banned-
