Author Topic: Galaga Bartop (99.9 percent done with pics) Update 11/16/2010  (Read 27944 times)
BobA
  • What Me Worry?
« on: November 04, 2010, 03:09:14 pm »
I am starting another bartop since I enjoyed putting the kit bartop together.  This one is a Galaga bartop with a very slim profile using an LCD monitor.
Progess to date.
Sketched out the side view and calculated the lengths of internal components.
Cut out sides and internal pieces.  Sides and CP piece slotted for T molding. Sides were cut with a template and a router to allow for easy replication.  All internal pieces were laid out on the template.
Internal pieces will be attached using screws and a Kreg Jig to cut pocket holes.
Here is a sketch of the cab and the components cut out.
edit: Added a completed pic so you do not have to go thru the whole tread.
« Last Edit: June 30, 2011, 12:51:43 pm by BobA »
  • Last login:Yesterday at 04:30:47 pm
Re: Galaga Bartop
« Reply #1 on: November 04, 2010, 03:17:29 pm »
Very cool Bob.
When I built mine, I connected the control panel to the kickplate part and used a roundover bit. I did this to try and emulate the stand up machine and it allowed me to use 1 piece of art. The downside is accessing the arcade. It's a pain!
How many buttons you plan on using?
BobA
  • What Me Worry?
Re: Galaga Bartop
« Reply #2 on: November 04, 2010, 03:24:00 pm »
Plan on a 3 buttons along with P1 P2 and Coin.  Joystick will be a Wico 8 way or a 4/8 way Ultimarc top switchable.
Edit this may change to 2 buttons instead of 3 as I hear 3 are not usually used.
« Last Edit: November 04, 2010, 09:13:34 pm by BobA »
IG-88
Re: Galaga Bartop
« Reply #3 on: November 04, 2010, 07:10:30 pm »
Very nice!  :cheers:  What kind of material are you using for the cab itself? Has it already been laminated? How about the hardware and software? Artwork? ;D
-HarumaN
BobA
  • What Me Worry?
Re: Galaga Bartop
« Reply #4 on: November 04, 2010, 09:12:14 pm »
Material is 5/8 inch black melamine coated mdf shelving. Two 6 foot shelves give enough material for both sides, interior pieces and left overs.  Exact hardware will not be discussed as I don't want to start a firestorm here.  There is no software required for the hardware. The screen is a 14 inch LCD mounted vertically with overall dimensions of 11 inches wide by 14 1/4 high. Artwork will probably be a Galaga marquee and side art reduced in size to fit the cab.  An atx power supply will power the screen and all other hardware, light and fan.
Thanks for asking ;D ;D
BobA
  • What Me Worry?
Re: Galaga Bartop
« Reply #5 on: November 04, 2010, 09:16:18 pm »
Looking at the access I think I will keep the front and CP separate to  make it easier to work on.
jmike
Re: Galaga Bartop
« Reply #6 on: November 05, 2010, 07:21:01 am »
Another one?
      Wish I had your dedication to the hobby and time.  ;D.
Can't wait to see more pics.
IG-88
Re: Galaga Bartop
« Reply #7 on: November 05, 2010, 08:13:29 am »
I think I know what you are talking about with the hardware. Got a couple of those myself.  ;)
Never thought of using black shelving. You get that at your local hardware store? I've seen white and blond or natural "wood" color but never black.
-HarumaN
BobA
  • What Me Worry?
Re: Galaga Bartop
« Reply #8 on: November 05, 2010, 08:47:05 am »
Got the shelving at Home Depot.  It is not in the shelving area.  It is usually found in around the area where they have melamine coated particle board 4 x 8 sheets and pine shelving.
« Last Edit: November 05, 2010, 09:38:29 am by BobA »
BobA
  • What Me Worry?
Re: Galaga Bartop
« Reply #9 on: November 05, 2010, 04:00:35 pm »
Used the Kreg jig to make pocket holes in all my interior pieces.   Ready now for assembly. Only piece that does not have pockets is the back panel which will be hinged with a lock.
« Last Edit: November 05, 2010, 04:02:20 pm by BobA »
BobA
  • What Me Worry?
Galaga Bartop
« Reply #10 on: November 06, 2010, 03:45:41 pm »
Here are some assembly pics of the bartop.
First pic - lots of clamps are needed - assembly being started.
Second pic - assembled side view
Third pic - front view - control panel needs to be laid out and drilled
Fourth pic - inside back view - fan panel needs a hole cut for fan and back piece needs hinge and lock. Neither piece mounted.
Note: in the last pic you can see the back view where I used the bull nose edge of the shelving to finish the sides as well as the
top and bottom of the cab.  The front sides and CP are slotted for t-molding.
Note: the small power screwdriver.  Since the cab is only 13 inches wide inside there is no way a regular sized drill will fit inside.
« Last Edit: November 06, 2010, 04:04:08 pm by BobA »
Re: Galaga Bartop (Now with assy pics)
« Reply #11 on: November 06, 2010, 06:31:05 pm »
Nice Bob, your on a roll!
Whats the price/time tally on build vs buy so far?
BobA
  • What Me Worry?
« Reply #12 on: November 06, 2010, 06:55:43 pm »
I think the bare cab will cost me about $35 in material vrs $135 for a kit plus shipping.  But since I used shelving for the melamine coated MDF I could not cut the size required for the kit that I purchased. The cost is only based on the slim galaga design cab.  Time to plan and cut the galaga cab about 1 week.  Time to receive the kit about 1 week.
Cost for the finished cabs is much much different.
Kit cab based on a dual core CPU and 500 GB hardrive and 2GB memory with 19 inch LCD and encoder, amp joystick and buttons etc about $650
Galaga scratch built cab with you know what hardware and PS with 14 inch LCD joystick and buttons about $350.
Once you start adding parts the cost difference is not very large.  If the Galaga cab was to get the same PC as the kit built cab the price would be about $550.  It is only alot cheaper right now because of the single board arcade being used for the hardware and not a PC.
« Last Edit: November 06, 2010, 07:46:48 pm by BobA »
abispac
  • Last login:December 04, 2025, 01:12:34 am
« Reply #13 on: November 06, 2010, 10:32:11 pm »
it looks so nice, i love it. good job  :cheers:
« Reply #14 on: November 07, 2010, 09:29:20 am »
Nice. Personally, I think the end goal justifies the path you take. If the journey is fun, than scratch built is the way to go. If the fun is playing, than pre-built is just fine.
Looking good.
BobA
  • What Me Worry?
« Reply #15 on: November 07, 2010, 10:11:33 am »
leapinlew - Yes I have to agree that your needs should dictate the way to go.   The one thing the kit did was bring back some fun as shown by me jumping right into a scratch build.
abispac - Thanks for the comment.
IG-88
« Reply #16 on: November 07, 2010, 10:21:53 am »
What is the width of the shelving? 12"? How bad do you think it would look if you would join 2 pieces together giving you a 24" width? Properly glued and clamped, would the seam show all that much?
I know at Menards they have that shelving in 36" widths tho not in black. Maybe you could order black that wide...
-HarumaN
BobA
  • What Me Worry?
« Reply #17 on: November 07, 2010, 12:24:23 pm »
The depth of the shelving is 15.5 inches.  That is why the sides of my cab are a max of 15 inches deep.
You could probably glue 2 12 inch together but it depends on what the surface is that you are gluing to.  Ideally it should be bare particle board or mdf.  This might mean ripping the shelving down a 1/4 inch if it has finish on all sides. The seam will probably show as the sides are already finished and it is hard to get an invisible joint.
I found my shelving at Home Depot not in the shelving area but in the wood and plywood area.
BobA
  • What Me Worry?
« Reply #18 on: November 08, 2010, 12:19:57 am »
Here is an oops due to the use of the Kreg Jig.   The bottom plate has 8 pockets in it as it is a major supporting piece.  Of course I cut t-molding slots in the bottom of the cab sides.   The screws ended up interfering with the t-molding slot so I had to cut gaps out of the t-molding to allow for the places the screws blocked the slot.  If I was to do it again I would leave 1/2 inch so the bottom of the cab would be raised and the screws would not interfere with the t-molding slot
Now with t-molding
« Last Edit: November 08, 2010, 12:39:10 am by BobA »
jmike
« Reply #19 on: November 08, 2010, 07:08:38 am »
    Awesome work as always. (I'm a Kreg Jig owner as well). Keep those pics coming.
Where are you getting the artwork from?
Bender
« Reply #20 on: November 08, 2010, 09:40:37 am »
Hey BodA,
project looks great, I'm working on a few very similar to this
I've used the Kreg jig for all my projects and did exactly what you did by cutting little slots out of the spine of the t-molding, and not once has it come lose or had any problems whatsoever, so I'll keep doin' it the same way
I love that I can take the whole thing apart If I need to
BobA
  • What Me Worry?
« Reply #21 on: November 08, 2010, 09:53:08 am »
   Not quite sure where to get the artwork yet but there seem to be quite a few higher res pics of Galaga art around.   I was debating whether to make it look like a Galaga cab or combine the Ms Pacman and Galaga artwork to make a anniversary reunion cab.  The Galaga cab is the easiest as the other artwork does not seem to be around in high res.
   Anyone have any preferences?
BobA
  • What Me Worry?
« Reply #22 on: November 08, 2010, 09:57:35 am »
Hey BodA,
Thanks for the comment Bender.  I absolutely loved your Benderama cab it was a work of art.  Being able to take a panel off if required is a definite plus.
jmike
« Reply #23 on: November 08, 2010, 11:04:10 am »
I vote for the combo Galaga/Ms Pacman art.
Will keep a look out for the high res artwork for you.
BobA
  • What Me Worry?
« Reply #24 on: November 08, 2010, 11:49:20 am »
Thanks jmike, thatitalian, abispac, Jefferson, leapinlew, IG-88, Bender, Rick, BurgerKingDiamond, The Evil Collector, ids
Votes    7 Combo
            5 Galaga
Update 11/15/2010  I cast my vote and went with a simple combo format.
« Last Edit: November 15, 2010, 05:35:14 pm by BobA »
BobA
  • What Me Worry?
« Reply #25 on: November 08, 2010, 12:05:45 pm »
3 combos available 20th Aniv and 25 Aniv and 30 Aniv
Hard to find images of the RH side of the cab for 25 and 30.
Edit:
30 Aniv may not even be released yet.  Actual name Pac-Man's Arcade Party.
This new release will feature twelve Namco classics: Pac-Man, Galaga, Pac-Mania, Galaxian, Rally X, Mappy, Dig Dug, Xevious, Bosconian, Galaga ’88, Rolling Thunder, and Dragon Spirit. For a display it will likely use an LCD monitor, like the 25th anniversary cabinets did. There is no release date or price listed for the unit at this time but it will certainly be released before the end of the year.
No official release yet so probably no artwork or even pics of the RH side.  The original pic looks like a rendering.
« Last Edit: November 09, 2010, 12:40:40 pm by BobA »
thatitalian
  • The Revolution Is Coming...
« Reply #26 on: November 08, 2010, 01:07:21 pm »
Wow, that 30th Aniv artwork is crazy! Do we have that available anywhere? I would definitely go with that!
Awesome build! :applaud:
abispac
« Reply #27 on: November 08, 2010, 02:33:01 pm »
Ill vote for a combo look, it has to be combo if you are using multiple games in it....  :cheers:
Jefferson
  • Last login:January 14, 2024, 08:50:59 pm
« Reply #28 on: November 08, 2010, 04:27:37 pm »
I'll be the snoozefest that votes for straight up Galaga!
Whats cool about it is that it'd be something familiar, yet miniature.
The anniversary things always look like a photoshop chop job trying to mesh different aesthetics (like throwing clip art all over marquees as some do here) I especially hate the 'two face' split look of that 20th ann cab.
« Reply #29 on: November 08, 2010, 05:29:10 pm »
As a Galaga Bartop builder, I vote Galaga.
Now that I think about it - what games are you wanting to play that require 3 buttons? I have a hard time needing more than 2. I usually only put 1 to keep the look clean even though I lose some games.
IG-88
« Reply #30 on: November 08, 2010, 05:48:32 pm »
1 vote for the combo artwork.
-HarumaN
BobA
  • What Me Worry?
« Reply #31 on: November 08, 2010, 06:17:12 pm »
Gunsmoke has 3 buttons for shooting directions. Left Center Right but it is not one of my favs so 2 buttons are probably good for me.
Edit:  Just checked the dip settings and it looks like there is a one button mode so I don't have to lose the game with 2 buttons.
« Last Edit: November 09, 2010, 08:30:44 am by BobA »
« Reply #32 on: November 08, 2010, 06:55:41 pm »
I would like to vote 6 more times for dedicated Galaga.
Why do you guys want his machine not to look as good as it can be? Shame on you!
IG-88
« Reply #33 on: November 08, 2010, 07:23:59 pm »
I hate to tell ya Lew but Galaga.....  :puke  Now Galaxian....  :cheers:
-HarumaN
« Reply #34 on: November 08, 2010, 07:49:43 pm »
I change my vote to 1 week ban for IG-88.
IG-88
« Reply #35 on: November 08, 2010, 08:17:46 pm »
I thought that would get a rise out of you.  ;D
-HarumaN
Bender
« Reply #36 on: November 08, 2010, 11:11:48 pm »
one more vote for a dedicated Galaga, those combos look cheesy to me (plus if you go that route I might be able to hook you up with some artwork)
  • Last login:November 29, 2025, 04:34:53 pm
« Reply #37 on: November 09, 2010, 08:05:44 am »
I vote dedicated Galaga, and have it on good authority that Saint agrees with me.
BobA
  • What Me Worry?
« Reply #38 on: November 09, 2010, 08:33:55 am »
Thanks Bender.  I am interested in Galaga artwork as the Galaga vote is increasing and the original title of my project is Galaga Bartop.
« Last Edit: November 09, 2010, 08:36:23 am by BobA »
BurgerKingDiamond
« Reply #39 on: November 09, 2010, 10:51:51 am »
I would really think that Galaga dedicated artwork would go without saying  8)
-Welcome to the Fantasy Zone.
