Author Topic: Looking for mountable USB port  (Read 2215 times)
MPTech
  • Last login:January 05, 2025, 03:58:54 pm
  • UltimateArcade completed!
« on: October 11, 2010, 10:54:15 pm »
I'm looking for a USB port that I can surface mount on a panel and plug into an internal USB hub.
I'm looking for a single port, but won't discount a dual port.
Pictures / links would be greatly appreciated.
MPTech
   Better living thru technology!   ;-)
Nips916
  • Last login:October 28, 2017, 07:50:52 pm
Re: Looking for mountable USB port
« Reply #1 on: October 11, 2010, 10:57:23 pm »
I used these on the side of my cabinet for my light guns.  They are definitively worth it.  Look great too.
http://www.lizardlick.com/Neutrik-NAUSB-W-B-AB-USB-Feed-Through-Black_p_222.html
EvilNuff
« Reply #2 on: October 11, 2010, 11:04:30 pm »
kegger
  • Last login:April 10, 2011, 10:59:14 am
  • There are no unsingable songs....
« Reply #3 on: October 12, 2010, 12:51:53 am »
« Reply #4 on: October 12, 2010, 07:25:23 am »
Wish I'd seen this back when I was looking....
The technique I used was to buy a cheap USB extension cable, cut a hole that matched it's size and just epoxy it into place. Works great, doesn't look too bad, and it is cheaper (though not by much)
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:December 16, 2025, 07:43:13 am
« Reply #5 on: October 12, 2010, 10:21:18 am »
These are what I'm recommending in the second edition of Project Arcade. Arcadeshop.de carries these as well. The A/B is reversible so you can have whichever connector you want facing out. An A/B cable to your computer's USB port and you have a nicely mounted A connector sitting in the front of your panel or wherever you mount it.
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
ahofle
    • Arcade Ambience Project
« Reply #6 on: October 12, 2010, 11:54:12 am »
I have the neutrik connectors as well.  The best thing about it is you only need to drill a single hole for a perfectly clean mount.  Most other solutions require you to route out a square shaped hole.
