Author Topic: Sealing MDF cut edges  (Read 4123 times)
  • Last login:November 29, 2025, 04:34:53 pm
« on: September 22, 2010, 11:25:10 am »
Woodworkers, I ask for a hand.
When I've cut my MDF for past projects, I'm always left with a pretty unsightly roughness when priming and painting, and am looking for "the word" on how to fix this before I start on my cabinet.  I won't be using t-moulding, and have done a bit of research, but have a couple of options I've read up on and wanted your opinions.
I've read that a solution of 3 parts wood glue to 1 part water, applied with a foam brush, let to dry and then sanded will solve the problem of the rough looking edges.  I've also read that you could apply a veneer strip to the edge, much like you would to finish a melamine sheet.
What have you done to solve this issue?  Is there a better way?
shan1784
  • Last login:September 11, 2014, 01:59:13 pm
Re: Sealing MDF cut edges
« Reply #1 on: September 22, 2010, 03:48:57 pm »
Thanks,
Mike
« Reply #2 on: September 22, 2010, 03:59:57 pm »
This should be all you need...
http://shoryuken.com/f177/how-paint-mdf-mirror-finish-worklog-191692/
I've read that before.  Now, I think I'll bookmark it!  Thanks!
WhereEaglesDare
    • My HomePage
« Reply #3 on: September 24, 2010, 08:51:50 pm »
WOW
