Author Topic: Help! Can not assign shift button on iPac2!?!?!?  (Read 1151 times)
ragnar
  • Last login:August 16, 2022, 10:40:56 am
« on: September 16, 2010, 11:39:13 pm »
So, my cab (see sig) is pretty much up and running.  now I am trying to get the ipac2 set up.  Everything is going great except that I can not assign the shift function.
What I am doing:
1) Launch winIpac
2) set to table view
3) click on P1/2 shift cell
4) Upon prompting, press button that I want to have shift assigned to
5) nothing gets assigned.
What am I doing wrong here?
MY FIRST BUILD:
ragnar
Re: Help! Can not assign shift button on iPac2!?!?!?
« Reply #1 on: September 16, 2010, 11:57:04 pm »
Owe, my head.
SOLVED!
OK, I have to click the "shift cell" then click on the cell that represent the iPac input within the GUI with the mouse that I want to act as the shift key.  I don't want to press the actual pushbutton.
After re-reading the message from winIpac, I understand its meaning.
MY FIRST BUILD:
Nips916
  • Last login:October 28, 2017, 07:50:52 pm
« Reply #2 on: September 17, 2010, 09:50:35 am »
I was going to reply because I had the same issue.   After staring at the screen for an hour I actually read the status which told you to click with the mouse  the button you wanted to use for the shift function.  I want that hour of my life back.
ragnar
« Reply #3 on: September 17, 2010, 10:07:57 am »
Only half an hour of my life.  I got lucky.  Actually, the solution was in another thread here at byoac.  I did a seearch for "ipac shift" that worked out.  But i owuld have to say that hte GUI is somewhat non intuitive in regards to setting the shift key.
MY FIRST BUILD:
