Author Topic: Sega Megalo 410 mame conversion  (Read 3849 times)
dfg
  • Last login:March 31, 2012, 09:17:03 am
« on: August 26, 2010, 10:59:34 am »
Ok so my Megalo 410 has finally arrived.Still waiting on for my jpac and arcadevga card, should be in next week.
Opened up the centre control panel and had a bit of a look inside,(does this thing look confusing as hell lol!) sorry if it is a bit of a silly question but i noticed 2 vga connections onto this board. Which one of the 2 would i need to plug into my Jpac once it arrives?
http://img840.imageshack.us/i/pic1rc.jpg/    the megalo
http://img833.imageshack.us/i/vgah.jpg/     side view
http://img838.imageshack.us/i/vga2.jpg/     other side view
http://img830.imageshack.us/i/vga3.jpg/     close up
i can take more pics if it helps.
BobA
  • What Me Worry?
Re: Sega Megalo 410 mame conversion
« Reply #1 on: August 26, 2010, 12:56:21 pm »
The Megalo 410 is capable of 31Khz for a direct PC connect.  It does not actually need an arcadevga board. AFAIK.   Not sure about the 2 vga connectors.
  • Last login:August 17, 2025, 04:58:40 pm
« Reply #2 on: August 26, 2010, 01:08:54 pm »
The monitor is a tri-sync, so you can use the JAMMA connector (or are these JVS only?) with your J-Pac and ArcadeVGA to get ALL arcade resolutions OR just use the PC VGA output in 640x480@60 into the monitors VGA 31kHz connector and only use the J-Pac for controls.
More info on the lovely Megalo 410 here: http://www.hard--candy.com/index.asp?page=Megalo+410
If the cabinet has the JVS wiring standard instead of JAMMA, you should sell your J-Pac and ArcadeVGA and get a JVS-Pac instead: http://jvspac.kirurg.org/
« Last Edit: August 26, 2010, 01:12:02 pm by emphatic »
dfg
« Reply #3 on: August 26, 2010, 11:04:50 pm »
how can i find out whether its the JVS wiring??
