February 13, 2026, 09:30:16 am
The monitor is a tri-sync, so you can use the JAMMA connector (or are these JVS only?) with your J-Pac and ArcadeVGA to get ALL arcade resolutions OR just use the PC VGA output in 640x480@60 into the monitors VGA 31kHz connector and only use the J-Pac for controls.More info on the lovely Megalo 410 here: http://www.hard--candy.com/index.asp?page=Megalo+410If the cabinet has the JVS wiring standard instead of JAMMA, you should sell your J-Pac and ArcadeVGA and get a JVS-Pac instead: http://jvspac.kirurg.org/
