Author Topic: Nanao MS8-26SU  (Read 2662 times)
stillvip187
  • Last login:August 30, 2010, 08:32:02 pm
Nanao MS8-26SU
« on: August 22, 2010, 11:51:05 pm »
Nanao MS8-26SU
hi all i have a Nanao MS8-26SU and this is what its doing can anyone give me any ideas on how to fix it thank you
:banghead:
Mikezilla
Re: Nanao MS8-26SU
« Reply #1 on: August 23, 2010, 01:13:35 pm »
Hm. For some reason that wont load for me. Can you explain what is happening? I have that same monitor, maybe I can help you out.
Kevin Mullins
    • Me on Myspace
Re: Nanao MS8-26SU
« Reply #2 on: August 23, 2010, 02:01:28 pm »
It's on the verge of vertical collapse, only about three inches of vertical image in the middle of the screen.
http://img801.imageshack.us/i/ki2.jpg/
Mikezilla
Re: Nanao MS8-26SU
« Reply #3 on: August 23, 2010, 03:22:14 pm »
Weird, that image wont load either. I am at work, so that might have something to do with it. Thanks for trying to give me a link Kevin. Could it be a sync issue? Mine was having a little of the same problem. I had to resolder the sync on the board. Had to re-do a couple of traces as well, but now it works fine. Now Im trying to sell it lol.  :laugh:
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: Nanao MS8-26SU
« Reply #4 on: August 23, 2010, 06:31:54 pm »
resolder the pins on the vert output IC.
given time, thermal cycling will degrade the connections.
stillvip187
Re: Nanao MS8-26SU
« Reply #5 on: August 23, 2010, 06:38:01 pm »
can you piont out were to resolder
http://img828.imageshack.us/i/nanaoms826sumainboardca.jpg/
stillvip187
Re: Nanao MS8-26SU
« Reply #6 on: August 23, 2010, 06:39:05 pm »
grantspain
Re: Nanao MS8-26SU
« Reply #7 on: August 23, 2010, 06:45:09 pm »
i thought i had already answered this,this is a very common fault on ms8 chassis
there is a capacitor and a resistor that crap out-i think if the cap goes first you get partial collapse
Change C433 R433
If full vertical frame collapse then also change R436 Q401 Q402 C437
note it is worth checking what qrz has already said and you should check out your yoke readings/connectors
Mikezilla
Re: Nanao MS8-26SU
« Reply #8 on: August 24, 2010, 01:17:31 pm »
Before you do the soldering, I would do what grantspain said. That could be it, because my problem was a little different, the image finally loaded for me lol.
Do what he said first.
