Author Topic: Any guide on techniques to do tidy cable work?  (Read 1145 times)
ranma
  • Last login:October 05, 2014, 08:44:01 pm
« on: August 20, 2010, 01:19:07 pm »
I've seen pictures of some CPs and cabs with really tidy cabling and although I have the patience, I don't know how to even start to do such kind of work. I really don't understand how they measure the correct size, tied them together, etc.
Any guides out there?
extendedplayarcade
  • The Games You Crave
    • Extended Play Arcade
Re: Any guide on techniques to do tidy cable work?
« Reply #1 on: August 20, 2010, 02:03:25 pm »
Stuff like these help.  I called them wire tie anchors but I don't know the official name of them
Hope this helps
ranma
« Reply #2 on: August 20, 2010, 04:31:29 pm »
I mean this kind of work:
or this:
Ginsu Victim
  • Comanche, OK -- USA
« Reply #3 on: August 20, 2010, 04:44:31 pm »
Yeah, Brent gave you the first step.
BobA
  • What Me Worry?
« Reply #4 on: August 20, 2010, 05:01:06 pm »
Use multi conductor cables or use separate wires and learn how to lace the wires manually.  Use nylon cable ties and supports freely.
Cable Lacing
ranma
« Reply #5 on: August 20, 2010, 09:16:57 pm »
Cable Lacing
ahh! that seems to be what I'm looking for, thanks!
bkenobi
« Reply #6 on: August 20, 2010, 09:21:31 pm »
I just used wire ties.  If you want to make sure it's neat, just make sure you leave excess wire on the component side prior to wiring things up.  make your wire bundles first, cut to length, then wire things up.  Think about how you will route the wire before you install buttons so that you can determine which way to make the switches point.
