Author Topic: UK Supplier of Bondo (or equiv)?  (Read 4440 times)
jimmy2x2x
« on: August 11, 2010, 12:52:02 am »
What can we get over here that does as good of a job as the mighty BONDO!
shrunkenmaster
Re: UK Supplier of Bondo (or equiv)?
« Reply #1 on: August 11, 2010, 02:47:45 am »
Hey Jimmy, Bondo is just body filler, I've used U-Pol (get it at Halfords) - smells fantastic ;D
You can also get a super smooth finish with wet'n'dry sanding like Ond's Retro Futuristic cab if you put in the time, but obviously you don't need to go mad if it's just for patching holes and dents.
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_203243_langId_-1_categoryId_165625
Anything like this will do the job really. Just be prepared to sand, sand, sand...............
Franco B
« Reply #2 on: August 11, 2010, 03:05:59 am »
The Lumberjackass
  • Last login:January 09, 2015, 08:58:56 pm
« Reply #3 on: August 11, 2010, 03:12:08 pm »
bondo = davids p38 , isopon.
the only difference is that bondo is a little more malleable and easier to apply .
davids p38 however is a better grade filler ( stronger ) .
the only downside to using p38 is that it sometimes leaves very small pin-holes  on the surface( trapped air ) .
davids now do a new version of p38 that is pin-hole free . check the website for the code :)
I may be a jackass , but im no fool !
polaris
  • veni vidi congai
« Reply #4 on: August 11, 2010, 03:57:46 pm »
thats going in the uk wiki, cheers
