Author Topic: Command line in Mame Config - Basics TAB  (Read 3679 times)
empardopo
  • Last login:November 17, 2025, 01:32:25 am
    • My personal forum
« on: August 04, 2010, 10:56:36 am »
I want to use Wolfmame 106 with MALA to record my game!
In the command line, i have put: %rom% -record %rom% -joy -skip_gameinfo -nov -noc but with that doesn't record the game.
However, if i use a bat file with this code:
c:\wolf106\mamep106-vc.exe %1 -record %1 -joy -skip_gameinfo -nov -noc
it works fine!!
What am I doing wrong?
loadman
  • Moderator
    • MaLa
Re: Command line in Mame Config - Basics TAB
« Reply #1 on: August 04, 2010, 07:37:25 pm »
The logs will show you what it is passing to mame.
empardopo
    • My personal forum
« Reply #2 on: August 06, 2010, 10:24:27 pm »
Loadman, what is the log file? mala.exe.log?
loadman
  • Moderator
    • MaLa
« Reply #3 on: August 06, 2010, 10:32:42 pm »
Yeah It's the name of *.exe.log  eg it could be mala1660.exe.log  or mala.exe.log depending what you are running. It will be easy to tell if you look at the mala folder and sort by last modified file.
Enable logging in the help and credit tab in configuration window
FYI this is what the code does:
Code: [Select]
       // replace %path%
                 param := StringReplace(param, '%path%', path, [rfReplaceAll, rfIgnoreCase]);
                 // replace %parent%
                 param := StringReplace(param, '%parent%', parent, [rfReplaceAll, rfIgnoreCase]);
                 // replace %rom%
                 param := StringReplace(param, '%rom%', rom, [rfReplaceAll, rfIgnoreCase]);
                 // replace %ext%
                 param := StringReplace(param, '%ext%', ext, [rfReplaceAll, rfIgnoreCase]);
When launched you see a line in the logs like:
2010/08/07  12:40:23.70   Info: Set dir: C:\mametable\mame\
2010/08/07  12:40:23.70   Info: Starting Game ***: Create process: mame89.exe centipdb
« Last Edit: August 06, 2010, 10:47:59 pm by loadman »
empardopo
    • My personal forum
« Reply #4 on: August 09, 2010, 12:51:02 pm »
Thanks. I didn't know that option.
koolmoecraig
    • My Intervention
« Reply #5 on: February 03, 2011, 03:26:12 am »
Wait.  So what did you do to get it working?
Gray_Area
  • -Banned-
  • -Banned-
« Reply #6 on: February 07, 2011, 07:47:52 pm »
Couldn't you just put that in the wolfmame ini?
-Banned-
