Author Topic: How to program new MiniPac?  (Read 3678 times)
Blanka
« on: July 13, 2010, 05:33:47 am »
I just installed a new minipac (the mini USB port UHID lookalike version), and it does not work with the WiniPac utility. I get an error "Failed to program device" error, after which the unit does not work any more until I replug it into the USB port. I also tried the U-config utility (as it looks like a UHID), but that one does not recognize the board at all. Do we need a new utility for the new MiniPAC?
Trap
  • Last login:November 07, 2015, 12:22:32 pm
Re: How to program new MiniPac?
« Reply #1 on: July 13, 2010, 04:25:13 pm »
I had this same problem when we built my friend's cabinet.  We ended up just making the default settings work.  Are you using Vista by chance?  I was having all sorts of trouble trying to install both winIPAC and the U360 software on his cabinet running Vista.
chill
  • Last login:July 05, 2019, 01:33:19 pm
« Reply #2 on: July 13, 2010, 11:27:52 pm »
I had the same issue trying to use Win 7.
find an XP machine and it should be ok.
Blanka
« Reply #3 on: July 14, 2010, 02:51:35 am »
It is running on XP,
I'll see if I can hook it to a Mac.
Blanka
« Reply #4 on: July 14, 2010, 03:25:27 am »
MacIpac can program the new MiniPac, but not the shift function. :(
I see it works partly as the changes in non-shift buttons are uploaded, where the shift ones don't
The DOS application under XP works but gives a time-out error when choosing program.
Tried WiniPac again, after programming, you get an error, and the whole controlpanel goes "offline" until you reboot.
« Last Edit: July 14, 2010, 04:18:54 am by Blanka »
Blanka
« Reply #5 on: July 17, 2010, 11:51:00 am »
Got a quick response from Andy:
Quote from: Andy Warne
On the PC, make sure you have the latest WinIPAC version and in "options"
select the 32-input I-PAC board.
On the Mac, select the I-PAC VE board (which has 32 inputs).
It worked!  ;D
Note that on the VE board, button 7 and 8 seem to miss, but they are named P1-A, P1-B, P2-A and P2-B
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #6 on: July 17, 2010, 01:18:27 pm »
On Vista and W7, the first time the program is run it needs to be run by right-click and "run as administrator" so the driver installs. Thats the usual issue with these versions.
