Author Topic: What is this material?  (Read 2318 times)
jimmy2x2x
« on: July 10, 2010, 01:02:43 pm »
I was walking home from town today, and passed a skip being used by a sign fitting company
A small sheet of aluminium caught my eye, I grabbed it intending to dremel it for the rear panel on my project.
When I got home I noticed that is wasn't all aluminium, I has a an aluminium face on either side with some kind of plastic/plexi/perspex inside it.
Its very easy to work with, heavy and very solid - this stuff will not bend.  I think it would be great for a control panel.
Anyway - here it is (part worked by me, not complete)
SavannahLion
Re: What is this material?
« Reply #1 on: July 10, 2010, 02:57:45 pm »
BobA
  • What Me Worry?
« Reply #2 on: July 10, 2010, 03:08:34 pm »
jimmy2x2x
« Reply #3 on: July 10, 2010, 03:18:44 pm »
Many thanks, Your knowledge of scientific biological transmogrifications is only outmatched by your zest for google-fu treachery.
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #4 on: July 10, 2010, 04:04:18 pm »
It's probably very toxic and can only be machined while using a gass mask :P
jimmy2x2x
« Reply #5 on: July 10, 2010, 04:12:01 pm »
hahaha (I hope!)
Well this stuff is great, I really want to make my CP from it
Im going to stop by the skip again, see if I can scrounge some more - I will try and talk to the workmen if they are around see if they have any offcuts ;)
TOK
  • Last login:January 24, 2024, 05:14:24 pm
  • The Game Always Wins
« Reply #6 on: July 10, 2010, 04:33:02 pm »
Bring a case of beer!  :cheers:
Benevolance
« Reply #7 on: July 10, 2010, 06:25:33 pm »
And wear your safety goggles.
bkenobi
« Reply #8 on: July 10, 2010, 11:14:06 pm »
NASA has worked with a similar material made from Titanium and Graphite panels sandwiched together.  I can't find a link to it, but it's often called TiGr (probably spelled differently, but pronounced "tiger").
I suspect that if you can find it, you would be looking at more expense for the CP base material than the rest of your next 3 cabinets!   :cheers:
ids
  • Last login:July 30, 2025, 08:56:20 pm
  • Fighter Captured
« Reply #9 on: July 11, 2010, 11:02:07 am »
Looks like it might also be good for the surface of an air-hockey table.  However, without seeing it directly, it's hard to say.  Is it as smooth and flat as they advertise?  A 4'x8' sheet is pretty cheap - if you live in china.  I bet shipping such a large thing would be very costly.  Google shows more localized sources, but no pricing.
jimmy2x2x
« Reply #10 on: July 11, 2010, 11:08:54 am »
I couldn't imagine anything more flat, smooth or rigid - it really is perfect for our hobby.  Im trying to source some in the UK, not much luck.
SavannahLion
« Reply #11 on: July 11, 2010, 11:30:31 am »
Based on BobA's link the U.S. supplier can be found at http://www.graphic-al.com/
Unfortunately, you have to inquiry for pricing. :(
Maybe if you contact them, they might be able to ship to the U.K. (expensive I know) or they might know who a U.K. supplier is.
« Last Edit: July 11, 2010, 11:33:59 am by SavannahLion »
bkenobi
« Reply #12 on: July 11, 2010, 11:51:01 am »
Pricing is not provided, but they do allow for samples.  I'm ordering the OR product line to see what it's like.  I suspect they will be no larger than 6" squares (optimistically), but that might be enough to play around with!  Btw, I don't recommend a bunch of people order samples all at once unless you are truly interested or else the company will eat a bunch of unnecessary shipping costs.  Just my opinion though.   :cheers:
ids
  • Fighter Captured
« Reply #13 on: July 13, 2010, 04:58:40 pm »
I spoke with a sales rep at Alcotex.  He says their product has a much higher quality finish than the chinese and indian products, which is why it's ~$5 per sq ft.  However, he pointed me to some local plastics and sign companies which would sell the cheaper stuff:
« Last Edit: July 13, 2010, 05:27:25 pm by ids »
jimmy2x2x
« Reply #14 on: July 13, 2010, 05:57:47 pm »
I visited my source today, and guess what? They are long gone! typical
ah well  :banghead:
I haven't had time to pursue a UK supplier yet, but I will
Beley
  • Last login:September 14, 2013, 09:02:37 pm
« Reply #15 on: July 13, 2010, 09:12:20 pm »
Ive used this (or something similar) in a project i did a while back, the brand name was Dibond, we found it fairly easy to work with, ie cuts easily with most tools and were able to bend it in a fairly tight radius.  The problem we had in the end was that it got dented to easily and being the brushed aluminium finish the small dent showed up quite easily.
Here is a link to the exact material we used[/tt]]http://www.lairdplastics.com/content/view/496/71/
bkenobi
« Reply #16 on: July 14, 2010, 11:23:10 am »
Link no worky.
I got an email from the graphic-al rep.  They will be sending the samples out soon.  As soon as I get them, I'll post my impression.  I think Beley nailed my concern on the head...the material may be easy to work, but how damage resistant is it.  I guess I'll find out soon!
gryhnd
« Reply #17 on: July 14, 2010, 11:54:41 am »
Link no worky.
It was just a typo or stray letters in his tags.  Just remove the trailing [tt
Completed: No Name Upright
