Author Topic: Jamma 60 in 1 speakers question  (Read 6026 times)
Darren01274
  • Last login:September 12, 2020, 10:05:08 am
« on: July 04, 2010, 07:15:20 am »
Hi what type of speakers can be used with the 60 in 1 jamma board can original arcade speakers be used? and how do you control the volume.
BobA
  • What Me Worry?
Re: Jamma 60 in 1 speakers question
« Reply #1 on: July 04, 2010, 08:29:11 am »
There is a volume adjust page in the service menu.   You can use a regular arcade speaker.
Darren01274
« Reply #2 on: July 04, 2010, 08:34:58 am »
Thanks. Stero or Mono Speakers.
BobA
  • What Me Worry?
« Reply #3 on: July 04, 2010, 08:41:55 am »
Most jamma are mono.
Bender
« Reply #4 on: July 04, 2010, 11:30:34 am »
there is a pot on the board that also controls the volume of regular speaker hook up
and a second option is to use powered speakers through the 1/8" jack that have there own volume control cause the board doesn't control the through the line out jack
also you need 12V hooked to the board to use the regular speakers hook ups (not the line out)
Darren01274
« Reply #5 on: July 05, 2010, 11:50:17 am »
How do you wire an arcade switchable PSU to jamma 60 in 1 so I could use arcade speaker
BobA
  • What Me Worry?
« Reply #6 on: July 06, 2010, 09:51:17 am »
If your power supply is wired to the jamma connector then the 60 in 1 will receive 5v AND 12v from the connector.   If it is not wired to the jamma connector then you can wire a 4 pin drive connector to the Arcade PS for 5V red 12V yellow and Ground black (2)
RayB
  • I'm not wearing pants! HA!
  • Last login:July 10, 2025, 01:33:58 am
  • There's my post
    • RayB.com
« Reply #7 on: July 06, 2010, 11:32:59 am »
He can also use a PC power supply.
NO MORE!!
