Author Topic: New I-PAC Firmware  (Read 12266 times)
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
New I-PAC Firmware
« on: July 02, 2010, 06:30:21 pm »
New I-PAC firmware is available. This is currently only for I-PAC 2.
At the present this will be Beta when used as an upgrade, although it has been field-tested. (Thanks to Dan from Surface Tension for this).
The change is the I-PAC will support the "consumer control" keys:
Power
Sleep
Wake
Volume Up
Volume Down
Any button can be configured as these functions.
The firmware upgrade instructions are here: http://www.ultimarc.com/fwupgrade.html
There is a note about minimum existing level.
The firmware is available on request: andy@ultimarc.com
kronic24601
  • Last login:June 24, 2014, 03:08:54 pm
  • Evil Arcade Monkey Strikes Again!
Re: New I-PAC Firmware
« Reply #1 on: July 22, 2010, 09:54:54 am »
Any word on when this will be available for the IPac-4? I would LOVE the Volume control.
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:February 07, 2026, 09:17:00 pm
« Reply #2 on: July 22, 2010, 10:09:38 am »
Power
Sleep
Wake
Volume Up
Volume Down
Woot!
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
Blanka
« Reply #3 on: July 22, 2010, 10:17:09 am »
Volume control on the new MiniPac please.....  :o
newmanfamilyvlogs
    • Newman Family Vlogs
« Reply #4 on: July 22, 2010, 11:35:44 am »
I was JUST wondering how to configure power-on via minipac.. I hope that will be available soon.
DillonFoulds
« Reply #5 on: July 22, 2010, 11:06:30 pm »
Oh man I can't wait for the volume controls on my ipac4! I set up the keys in winipac, but it just doesn't quite seem to work! :(
kronic24601
« Reply #6 on: July 23, 2010, 10:40:45 am »
DillonFoulds
« Reply #7 on: July 23, 2010, 11:40:41 am »
Thanks Kronic24601! Any idea about the jumper wire? I'm thinking it's something simple like grounding that pin, I'll have to take a closer look at home this evening.
« Last Edit: July 23, 2010, 12:49:02 pm by DillonFoulds »
kronic24601
« Reply #8 on: July 23, 2010, 12:39:19 pm »
good question, I asked Andy and will post back when I found out (unless he beats me to it) ...
DillonFoulds
« Reply #9 on: July 23, 2010, 12:53:38 pm »
Looks like it should be as straight forwards as this:
kronic24601
« Reply #10 on: July 23, 2010, 01:48:28 pm »
That was my assumption, but I'll ask just to be sure
EDIT: Yes, that is correct. I have done the update. One thing to note, this will not work if you use the PS/2 connector, you will need the USB adapter or cable to do both the update or to utilize the features of the update.
« Last Edit: July 28, 2010, 10:59:47 am by kronic24601 »
DillonFoulds
« Reply #11 on: August 07, 2010, 10:30:17 pm »
Hmmm... I've recently purchased my I-pac4 (ps2 version), so where does that leave me? Does a USB-PS2 interface work, or are the two totally different, then?
kronic24601
« Reply #12 on: August 07, 2010, 11:39:52 pm »
1) So far as I'm aware, all the Units have a PS2 interface on the board itself. Andy sells a PS2-USB cable if you want the cable portion. If you want to use the this software update, you need to use USB in one form or another. I used a USB/PS2 Adapter that you can get pretty much anywhere and it seems to work fine. Apparently however there are "converters" which are different than an adapter, and these will have problems ... so you don't want a converter, you want an adapter. Problem is, most websites don't make any clear distinction between them, but I think most are adapters.
tsaylor
  • Last login:April 20, 2019, 05:16:20 pm
« Reply #13 on: August 08, 2010, 11:37:16 am »
Has anyone heard if this is relevant to the MiniPAC (or if an update is planned for that board too)?
GoingIncognito
  • Last login:February 23, 2011, 12:57:44 am
« Reply #14 on: August 08, 2010, 02:39:21 pm »
I hope the MiniPac gets a firmware update :)
jtslade
  • Last login:January 22, 2026, 03:19:42 pm
  • Keep it looking originallish!
« Reply #15 on: August 09, 2010, 03:00:23 am »
Yeah Minipac.. that would be nice.
It looks like from the Ultimarc link that the MiniPac will have a firmware upgrade...
But I am unable to find any firmware download links on the site?
Is there another location that I am missing for download?
« Last Edit: August 09, 2010, 03:12:42 am by jtslade »
Ms. Pacman Original Cocktail with Non destructive mod to Groovy Arcade Linux with All 4way Vertical Cocktail capable 2 button or less games.
Neo Geo MVS Mame Cab Running Hyperspin, 25" Nanao Arcade Monitor, Mini-pac, ATI Radeon HD 4850 (ATOM-15), IL 8 Way Euro-Sticks from Paradise Arcade, Win XP 64bit, and tons of other junk.
kronic24601
« Reply #16 on: August 09, 2010, 10:28:22 am »
have you tried emailing Andy Directly  ;)
AndyWarne
    • Ultimarc
« Reply #17 on: August 11, 2010, 03:18:14 am »
We do have a MiniPAC version of this firmware, in fact it was beta tested first on the MiniPAC.
I will get it released when we are back in the office on 20th.
Andy
newmanfamilyvlogs
« Reply #18 on: August 11, 2010, 05:58:45 am »
And we'll need to email you then for a copy of the new firmware, correct?
Epyx
  • "You're an oddity"
« Reply #19 on: August 11, 2010, 11:19:22 am »
Awesome Andy!  I can't believe I missed this.  :cheers:
Last Project
Epyx Tutorials:
Tutorials
DillonFoulds
« Reply #20 on: August 11, 2010, 12:52:29 pm »
Grabbed my PS/2-USB adaptor from work today. I'll give it a go after work tonight.
Marsupial
  • Last login:April 17, 2024, 09:00:56 pm
  • I am teh Mars!
« Reply #21 on: August 11, 2010, 01:06:28 pm »
Andy
my brand new minipac seems to handle the volume up/down pretty well... ain't that part of the new firmware?
-Mars
DillonFoulds
« Reply #22 on: August 12, 2010, 07:26:29 pm »
Hey guys, i've got one of these i've tried updating with and it was no go:
Would it be worth trying one like this: (readily available from a friend, 20 minute drive away)
http://www.startech.com/item/USB2PS2-USB-to-PS2-Keyboard-and-Mouse-Converter.aspx
Or do i need "less", such as one of these:
EDIT: What's the ipac 4 USB pinout like? Can I wire up a cable myself from a ps/2 extension cable & usb extension cable i have tons of laying around?
« Last Edit: August 12, 2010, 07:40:01 pm by DillonFoulds »
Blanka
« Reply #23 on: August 13, 2010, 02:42:49 am »
How is it with the software? Which programs let you assing volume buttons. Can it be added to the MacIpac program. Are the key options is some XML list inside the application?
AndyWarne
    • Ultimarc
« Reply #24 on: August 13, 2010, 03:54:09 am »
To change from PS/2 to USB, a PS/2 to USB conveyer is not what you need because all I-PACS are already USB so all you need is either the cable we sell or a small plug type of adaptor.
Andy
AndyWarne
    • Ultimarc
« Reply #25 on: August 13, 2010, 03:56:37 am »
The WinIPAC program already supports these extra key functions, in the right-click menu when assigning keys, under the macro assignments.
Andy
DillonFoulds
« Reply #26 on: August 13, 2010, 07:38:16 pm »
Sorry, i should have responded earlier.
Last night i followed these pinouts to program my I-pac4.
http://pinouts.ru/InputCables/usb_ps2_mouse_pinout.shtml
Everything went smoothly!
DillonFoulds
« Reply #27 on: August 15, 2010, 12:08:56 pm »
Something else I should have pointed out... My I-Pac4 upgrade wiring above is wrong. Is should be on the second terminal, not the third. The one it's on now, even though appears to be labelled GND is actually Coin1. To clarify, the pin is correct, but it needs to be connected to any ground terminal (the shielding on the PS/2 ports should work as well).
jtslade
« Reply #28 on: August 20, 2010, 05:33:34 am »
Bump for the new firmware....
Andy how was the vacation.. Did you find a beach somewhere.. Croatia maybe..
DillonFoulds
« Reply #29 on: August 20, 2010, 04:42:13 pm »
To be honest, I'm kind of surprised and disappointed that this new firmware hasn't made a bigger fuss.
crip102468
  • Last login:August 01, 2025, 11:04:56 am
  • My house is your house.
    • TomorrowzWeaponz
« Reply #30 on: August 28, 2010, 09:38:19 am »
Were can i download this new firmware?
DillonFoulds
« Reply #31 on: August 28, 2010, 04:00:34 pm »
Depends on what model of i-pac you have. There are some links posted above.
crip102468
    • TomorrowzWeaponz
« Reply #32 on: August 28, 2010, 04:01:27 pm »
Its for ipac2 ty. but were is the link for this?
Encryptor
  • Trade Count: (+34)
« Reply #33 on: August 28, 2010, 09:55:59 pm »
Encryptor
