Author Topic: tball+spinner and 2 rotaries?  (Read 1185 times)
night
  • Last login:January 09, 2018, 02:08:19 pm
« on: August 03, 2003, 09:03:00 pm »
how do i wire this. i have/had the tball like normal, then the 2 rotaries using X/Y, and then i put the spinner in X with the number 1 rotary. but that wont work. when i do that the spinner just flickers back and forth.
am i gonna have to go to 98 for 2 mice ?
Magnet_Eye
  • Last login:May 11, 2020, 09:26:19 pm
  • Feel the heat?
    • Web Hosting deals for BYOAC Users!
Re:tball+spinner and 2 rotaries?
« Reply #1 on: August 03, 2003, 09:27:51 pm »
probably. you are using XP right now?
I did this setup you want in win98 SE.
I offer discounted WEB HOSTING to BYOAC members! Only $2.49 a month for a FULL FEATURED account! www.cloud9media.com
night
« Reply #2 on: August 03, 2003, 09:46:16 pm »
that really sux.
for 1 frickin spinner.
i dont know how having 2 hooked up messes up the other when only 1 is even spinning  >:(
OSCAR
    • Oscar Controls
« Reply #3 on: August 03, 2003, 09:57:36 pm »
What are you using now to interface the trackball & spinner?  Opti-PAC?  When an optical device just flickers, that is usually an indicator of misaligned optic board or fried phototransistor.
Going to Win98SE will only really help if you plan to use Analog+, it doesn't have anything to do with having multiple mice for a trackball and spinner unless you need to assign the mice to different players.
SirPoonga
  • Puck'em Up
  • Last login:August 18, 2025, 08:28:46 pm
  • The Bears Still Suck!
« Reply #4 on: August 03, 2003, 10:11:42 pm »
Actually, you only need analog+ with win98 if yo have two mouse devices.  Two spinners is one mouse :)  You can use analog+ to split axis in any windows.
OSCAR
    • Oscar Controls
« Reply #5 on: August 03, 2003, 10:20:35 pm »
In my disjointed rambling, that is exactly what I was getting at.  Going to Win98SE really only helps if you need to use Analog+ to assign different mice to different players.
Axis splitting/switching is a different issue, and not what the original poster was asking about if I understand correctly.
« Last Edit: August 03, 2003, 10:21:07 pm by OSCAR »
night
« Reply #6 on: August 03, 2003, 11:39:07 pm »
ok, nm. i forgot about the port 2's going to port 1 when in 1 player mode. so i can connect them all seperate.
if i can get the opti to work now.
has anyone ever had the opti not install cuz xp insists on using exact drivers?
it only detects it as 1 mouse, and then it wont work with the "HID compliant mouse".
on my other comp (which has now been formated) i remember it installing the HID compliant and some EP2 thing that i cant find now  >:(.
this has just not been my day.
Zakk
  • Last login:Today at 01:56:03 pm
« Reply #7 on: August 04, 2003, 07:39:12 pm »
Hey, if you do get it figured out, be sure to post, as I plan to so the exact same setup in the near future on a cab.  I assumed that the optipac would accept input from both devices no problem.  I would hazard a guess that you would have to power each separately, instead of leeching all the 5V leads off the opti-pac.  Using the 5V power from the computer supply has always worked for me, and I was intending to wire that way for this upcoming panel.  Like I said, keep postin'  :D
Aceldamor
« Reply #8 on: August 04, 2003, 10:41:13 pm »
Another possibility is to use Oscar's rocker switch
http://www.oscarcontrols.com/DPDTswitch.shtml
You can use the same idea with 2 spinners/Rotaries (assuming the rotaries are optical)  that way you can use 1 mouse for 4 devices.
Just have it switch between the rotaries and the spinners.
Fuzzy Wuzzy was a woman!
