Author Topic: First build from scratch advice: TV or CRT Monitor?  (Read 3738 times)
XNIF
  • Last login:January 18, 2017, 04:40:32 pm
« on: June 30, 2010, 02:39:51 pm »
I know there are plenty of topics about it and i have read a lot too. I know TV has almost the result of an arcade screen and that a CRT is too sharp and gives a somewhat crippled result with games on a lower resolution as the monitor can handle.
So you would say go for the tv. But what makes me hesitate is the way i must connect a TV. I am in NO way an electrician, and i do not understand much about electricity. And i am worried for my life ! hehehe :timebomb:
On the other hand, i am quite handy and i am a computer and networking expert. And connecting the wires on the CP does not scare me.  I wanna know if it's feasible for me to do it?  And if i do go for a CRT monitor will i regret it? Is it really so much worse?
thanks in advance!
« Last Edit: June 30, 2010, 02:41:34 pm by XNIF »
  • Last login:July 23, 2025, 07:04:20 pm
Re: First build from scratch advice: TV or CRT Monitor?
« Reply #1 on: June 30, 2010, 02:42:18 pm »
I would say CRT.  I've built a couple of machine with PC monitors and I've been very happy with the results.
Baldark
  • Last login:February 20, 2017, 02:44:57 am
« Reply #2 on: July 21, 2010, 07:40:51 am »
I would say CRT because I toyed with both.  With the crt, you have more options to mess with the display more than a normal tv.  The normal tv lacks many options and requires a pc that has tv-out ability.  Plus, navigating and browsing with a tv is very difficult because of how blurry the font is.  If you have both at your disposal, try both of them out.  I am currently using a 27 inch tv and suffer from the lack of sharpness.  I went with a tv so I could hook up my ps2 and ps3 without any trouble.  I also went with it because it is huge compared to my 17 inch crt.  Even though the tv is blurry, games look great on it.  I guess it depends on your setup.
XNIF
« Reply #3 on: July 21, 2010, 08:12:02 am »
Thank you for you response all. I bought a 25" trinitron tv with scart (RGB).  A small screen just doesn't cut it for me. I really want to "feel" the arcade history if you know what i mean, and a 21" is a lot smaller. And i will make connection for vga/dvi and usb on the frontside of the cabinet in case i need to connect a monitor.
Epyx
  • "You're an oddity"
« Reply #4 on: July 21, 2010, 10:19:44 pm »
Seeing as your tv is a SCART capable tv and you like a big screen its a no brainer. You can get adapaters online if making one scares you but honestly you don't have to be an electrician...basic soldering and that's about it.
Last Project
Epyx Tutorials:
Tutorials
Eddie_Brock
  • Last login:February 26, 2014, 12:00:34 pm
« Reply #5 on: July 23, 2010, 12:41:11 pm »
For a first project, my opinion would be to go for a TV.
Connection is as simple as a power cord and video input. Do like I did and modify your designs so that your tv will fit inside the cabinet without needing to be decased.
Just my two cents.
XNIF
« Reply #6 on: July 24, 2010, 06:11:40 am »
Just my two cents.
thanks... but i will de-case it. I have found someone who is an electrician, he will decharge it for me for free.
I do not wanna use the speakers from the tv, and the case is just too wide. I have some pics of the trinitron here: http://forum.arcadecontrols.com/index.php?topic=103777.0
« Last Edit: July 24, 2010, 06:14:02 am by XNIF »
BonzNumber1
  • Last login:January 11, 2012, 05:33:25 pm
  • 2 1337 4 U
    • BonzNumber1
« Reply #7 on: November 08, 2010, 01:59:03 am »
Just my two cents.
ok i have a question about this as i am mounting a 25 inch true flat tube style tv.  how can i make it turn on every time it gets power without the need to hit the power button on the tv every time
Celsius
  • Last login:May 10, 2015, 11:40:41 am
    • Rcade project
« Reply #8 on: November 08, 2010, 02:13:46 am »
you'll have to go in service mode to make it switch on, on power. To find the key combination to get in service mode, type model nr + service mode in google, but look out changing the wrong options could mess up your tv.
BonzNumber1
  • 2 1337 4 U
    • BonzNumber1
« Reply #9 on: November 08, 2010, 02:32:34 am »
thanks i'll look into it you should take a look at  my thread bellow as that is the project i'm doing it for
Nacimroc
  • Last login:October 20, 2015, 03:46:25 pm
« Reply #10 on: November 08, 2010, 07:51:28 pm »
Or just shove something into the power button! Or if you have decased it join the wires from the power button. (assuming it autopowers on when power button is held in)
