Author Topic: MaLa errors  (Read 3106 times)
Onyx_PghPA
  • Last login:January 20, 2011, 06:03:02 pm
MaLa errors
« on: June 25, 2010, 03:42:22 pm »
I posted this over in the Software forum, but it was, um, "suggested" that I put it here. Tried to get it moved, but no luck, so I'm re-posting:
Having two problems with MaLa; after spending weeks finally fixing all of my other emulation problems.
1)  It seems whenever I exit a game using ESC (either the ESC button on a keyboard or the control panel button I have programmed for ESC), I get an error message:
http://www.flickr.com/photos/pctech714/4686280823/#
2)  Whenever I first load MaLa, have DAPHNE selected as my emulator and right-click and select options, a bunch of error messages pop up:
http://www.flickr.com/photos/pctech714/4686932782/#
Anyway, anybody encounter these problems and know of a solution.  #2 is fairly minor -- I know just to avoid making changes to options in DAPHNE, but the first one kinda sucks.
Thanks,
Joe
My arcade cabinet hardware:
MSI K9N6PGM2-V motherboard (onboard video and 10/100 networking)
AMD 64 X2 4800+ CPU
2GB DDR2 800 RAM
16GB solid state hard drive
27" D9800 Wells Gardner arcade monitor
Windows 7 Ultimate 32-bit
MaLa and Ultramap are on the cabinet's hard drive, but the emulators, ROMs, etc. are all on a shared network drive on my server PC.  Control of the cabinet (for making changes and so forth) is done through PC Anywhere, so I don't need a keyboard or mouse. I'm using MAME v0.138 (the most recent, command-line, full version). I have also deleted all of the .cfg files for each game. All drivers are current.
"mmmmm...control panel finished... <drool>"
loadman
  • Moderator
    • MaLa
Re: MaLa errors
« Reply #1 on: June 25, 2010, 08:30:55 pm »
1) I have not seen that Mame error before. I just used 138
2) The error says to ckeck the mala logs. What do the logs say?
- Are you using the latest mala beta? I suggest doing that and setting the logging level to verbose and sending the relevant log section.
Onyx_PghPA
Re: MaLa errors
« Reply #2 on: June 28, 2010, 06:53:41 pm »
I eliminated the redundancy, but the following error messages were repeated multiple times when run on different dates:
2010/04/21  17:10:23.99   Error: Object Class: TTimer, Object Function: PlaySound, Exception Class: EAccessViolation, Exception Message: Access violation at address 0044D1A8 in module 'MaLa.exe'. Read of address 00000004
2010/04/22  20:34:18.55   Error: Object Class: TTimer, Object Function: LoadLEDConfig, Exception Class: EAccessViolation, Exception Message: Access violation at address 005613B3 in module 'MaLa.exe'. Write of address 00000010
2010/06/09  19:14:14.17   Error: Object Class: TPopupList, Object Function: LoadLEDConfig, Exception Class: EAccessViolation, Exception Message: Access violation at address 0044D1A8 in module 'mala.exe'. Read of address 00000004
There was a stack overflow after all of the above, but I lost it somewhere. Guessing the huge number of the above error messages caused it.
This was from using the most current full release. I just installed the beta and will follow up later in the week with my results from that.
Joe
empardopo
  • Last login:Yesterday at 03:59:43 pm
    • My personal forum
Re: MaLa errors
« Reply #3 on: June 30, 2010, 06:04:01 am »
Windows 7 could be the problem. Have you checked the same configuration in another SO? I recommend windows XP to have less problems.
Onyx_PghPA
Re: MaLa errors
« Reply #4 on: July 07, 2010, 05:58:21 pm »
I'm guessing you meant O/S.  Just for the heck of it, I wiped the drive clean and did a new XP SP3 32-bit installation.  MAME is still crashing whenever I exit a game.
Also, I'm now using the most recent MaLa beta and getting the same result.
I'm starting to think it's a MAME problem.  I might revert to a previous release to see if that works.
Joe
Onyx_PghPA
Re: MaLa errors
« Reply #5 on: July 10, 2010, 01:20:36 pm »
Reverted to 0.136 and the problem goes away.
