Author Topic: Possible to connect maximum force gun to pc?  (Read 1732 times)
brad808
  • Last login:May 22, 2023, 08:18:15 pm
« on: June 22, 2010, 07:43:24 pm »
Hey guys,
I've tried searching around a bit and as far as I know this isn't possible. I'm transforming my Maximum force cabinet into a Mame cab and it seems like such a shame to have to get rid of the guns. Is it possible to connect them to the computer (short of replacing the optical sensor with something like aimtrack)?
kronic24601
  • Last login:June 24, 2014, 03:08:54 pm
  • Evil Arcade Monkey Strikes Again!
Re: Possible to connect maximum force gun to pc?
« Reply #1 on: June 23, 2010, 01:05:22 pm »
Anything is possible, I mean, the original arcade is technically a computer, and it works with that. However, if you cannot program this to work yourself, it ain't going to work. I hacked up some older guns I had and used the Aimtrack, it was the easiest solution.
92greenyj
  • Last login:January 02, 2012, 06:19:41 pm
« Reply #2 on: June 27, 2010, 12:27:16 am »
not sure about your Max force, but I know on my modern arcade gun games in my work arcade (Big Buck Safari, Primeval Hunt) the guns are just USB light guns.
