Author Topic: Nonstop background music  (Read 8009 times)
xsoft
  • Last login:September 29, 2010, 02:47:04 pm
« on: June 15, 2010, 10:08:54 am »
Greeting,
Im new here. I rear a lot of toppic here, wiki and our link. I didnt find answers so Im writing them here.
1. At MaLa frontend if I turn on Background music (shuffle, 505 volume, 10x MP3), then they are playing nonstop. Even if I run game, thig music is still playing. Can I disable or shutdown MaLa before game start and turn if back after gem end?
Note: Im using MaLa as fronend for PC games (DDR, ITG, IIDX, ..). All based on Batch commands.
2. Im unable to make work StartUp video. If I entered it at config page, nothing is happened. Just with video:on I have same black lines at menu (menu normally works). With video:off, menu still works without lines.
3. (its probably connected with point 1). I have some buttond set fo game start. If I push if, game normally starts from MaLa. But if I press this key again, it starts next instance. I can run one games 10times .. well .. this is not wanted state. MaLa still reveive comands from Joystick device if game starts? Thats strange.
Thanks you for tips.
Im now on this:
And I was on this: (no MaLa, no MaMe)
xsoft
Re: Nonstop background music
« Reply #1 on: June 15, 2010, 02:22:08 pm »
Point 1 and 3 solved. I start Batch that start other program. (changed "start" to "call" at batch and all works fine).
I/O
  • Last login:June 06, 2011, 01:33:10 am
« Reply #2 on: June 16, 2010, 04:59:50 am »
Mala has options for music to paused at game start, etc. As for controls, be careful what your settings are for each feature.
mark_navigator
  • Last login:August 03, 2010, 04:20:11 pm
« Reply #3 on: June 30, 2010, 05:44:25 pm »
.......sorry...but pheraps it's a Mala last stable version bug....I remember to have already alerted about that problem....is there any solution now?
mark_navigator
« Reply #4 on: July 07, 2010, 05:06:22 pm »
Can someone update the situation about that problem, please?
I need to get a fixed Mala release to use with my cabinet............
loadman
  • Moderator
    • MaLa
« Reply #5 on: July 07, 2010, 10:54:17 pm »
Hi
Well so you only have problem '2' remaining.?
 I set a video to run and startup and it worked fine. Hace you tried a xvid encoded video?
mark_navigator
« Reply #6 on: July 08, 2010, 12:39:49 pm »
How has been solved the 1st problem?
I've Mala working with Mame games and getting a game launched, background music still play.........
loadman
  • Moderator
    • MaLa
« Reply #7 on: July 08, 2010, 09:00:48 pm »
  I was asking because of this quote:
I just tested it and it works
Set:
options - gui - Game Start/quit - Pause music on game start
mark_navigator
« Reply #8 on: July 10, 2010, 07:38:46 pm »
Excuse me, Loadman,
but that option is already selected.........however, background music is still playing after a game launching........I'm using 1.62g Mala version!
loadman
  • Moderator
    • MaLa
« Reply #9 on: July 10, 2010, 09:44:53 pm »
Excuse me, Loadman,
Excuse me, Loadman,  ::)   :P  Sorry both that came across as rude. Happy to provide this FE for free and help those who don't give me attitude,
Anyway  ;)   1.62g is an old beta
Please tell me if the issue still exists for you in the latest beta.
« Last Edit: July 10, 2010, 10:33:10 pm by loadman »
mark_navigator
« Reply #10 on: July 31, 2010, 07:14:41 pm »
....yes, now I've just tried with 1.659 version and the problem is still present.
And worse, loading "out run" game I've got the Mame shell loaded but in background, on the foreground stays the Mala gamelist screen......... :cry:
loadman
  • Moderator
    • MaLa
« Reply #11 on: July 31, 2010, 08:12:03 pm »
MaLa loads all the games the same way so I have no idea why "out run" is different for you.
As for the music not pausing you will need to send me your mame.ini as post the last page of error log in verbose mode. It works for me. You are talking about music that 'mala' is running right? Not some other music player?
empardopo
  • Last login:November 17, 2025, 01:32:25 am
    • My personal forum
« Reply #12 on: August 01, 2010, 05:47:49 am »
Excuse me, but where is the 1.6.5.9 of MALA version to download?
I'm using the 1.6.5.0 and i've the same problem that mark_navigator says!
Loadman, thanks very much for MALA!
loadman
  • Moderator
    • MaLa
« Reply #13 on: August 01, 2010, 07:04:02 am »
1.659 is so last season, use 1.660  ;D
DOWNLOAD HERE  ;)
Any issues please post your mala ini and the end of the mala log in verbose/debug mode.
empardopo
    • My personal forum
« Reply #14 on: August 01, 2010, 08:57:29 am »
Thanks to you!
You should have a fixed post pointing to the last version of MALA. It's only my opinion.Thanks again!
I'll test with this new version of MALA.
mark_navigator
« Reply #15 on: August 03, 2010, 04:17:59 pm »
Yes, it's about background music.....
Here's my mala.ini file.......
About .log file, I didn't get any .log file....(even if I set up verbose mode and error log writing.....)
Ah, another thing, I don't think the loading problem is for Out Run only, I tried another one and the problem was the same......
« Last Edit: August 03, 2010, 04:19:53 pm by mark_navigator »
loadman
  • Moderator
    • MaLa
« Reply #16 on: August 03, 2010, 08:34:14 pm »
look for
 mala.exe.log
