Author Topic: Trackball only working vertically?  (Read 1982 times)
Huskerfan
  • Last login:October 05, 2021, 11:40:38 pm
« on: June 14, 2010, 04:51:01 pm »
I have a Happs trackball in my homemade standup arcade machine and recently it's started to only work vertically.  I try to go sideways with it and it won't.  I troubleshooted with a standard mouse and the mouse works just fine.
I assume maybe there's a switch attached to the trackball board that's burned out or something?  Just thought I'd ask you guys before I buy a new trackball.  Maybe a simple fix. :)
Thanks in advance.
Smeghead
  • Better Smeg than dead
    • MY MAME BUILDS
Re: Trackball only working vertically?
« Reply #1 on: June 14, 2010, 06:17:46 pm »
Dont mean to offend, just gotta ask, is the connector on the right way?
same happened to me and if it isnt the wires arent in the right place
switch em around and see if it only goes l-r
My MAME Build:
Huskerfan
« Reply #2 on: June 14, 2010, 06:41:40 pm »
Hey, no offense!  I'll take any advice!
Are you talking about the usb connector?  Cause those only go in one way.
Smeghead
    • MY MAME BUILDS
« Reply #3 on: June 14, 2010, 10:20:37 pm »
no the 4 or 5 pin connectors that attach to the circuit board on the trackball
Mines a Happ and it has 2 boards, 1 each side that hold the transmitters and receivers for the wheels to pass through. If the connectors that attach to those are the wrong way round youll get this behaviour as I did
Also of course make sure the wheels are actualy turning when you move the ball
My MAME Build:
« Reply #4 on: June 14, 2010, 11:18:51 pm »
If it's USB and it's connected to a hub, make sure the hub has enough power to run everything that's connected to it.
Many powered hubs are actually underpowered.
I had probs with my trackballs and U360's till I got decent hubs with enough power for everything attached to them.
Huskerfan
« Reply #5 on: June 15, 2010, 02:04:48 am »
Thanks for the reply's.  I really appreciate the help.
It worked before and I didn't do anything to disrupt it so I don't think it's hooked up wrong.
It's hooked directly to the motherboard usb so there should be plenty of juice.
I'm gonna try to troubleshoot by hooking it up to my laptop tomorrow and see if it works on it.  I'll report back.  thanks again!
BobA
  • What Me Worry?
« Reply #6 on: June 15, 2010, 09:07:02 pm »
Huskerfan
« Reply #7 on: June 16, 2010, 10:52:33 am »
Thread on Happ Trackball Problem
BobA,  I think you're on to something.  Looks like my problem is that small board.
Thanks a lot for finding that thread.  I have an email in to the guy that posted and said he carries these.
Thanks again!
Gary
