Author Topic: To all those who used the diode/Dreamcast method..  (Read 1868 times)
crashdmj
  • Last login:August 26, 2003, 08:55:42 pm
  • Hulk smash!
    • Best webpage in the Universe!!
« on: August 01, 2003, 07:43:59 pm »
I have a few questions that have been bugging me lately.....
So I read this thread: http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=8562;start=msg64520#msg64520
1) How do you share the monitor with the video card and the VGA box (can both be plugged in together)?
2) Do you leave the computer on while the dreamcast is on....or can you without it affecting anything?
3) When hacking a dreamcast pad where do the grounds (Upground, start ground etc) from the pad go?
4) Can the Dreamcast share the speakers with the PC? How?
I think thats all for now.
Derek
shmokes
  • Don't tread on me.
    • Jake Moses
Re:To all those who used the diode/Dreamcast method..
« Reply #1 on: August 01, 2003, 08:08:26 pm »
Hmm....I haven't done this but I think you can get a KVM box that will autodetect a signal, though I guess you'd have to shut down your PC to get it to quit sending a signal.  If you don't mind opening up your cab to hit a button on the KVM box you could just plug both the dreamcast and the PC into the KVM and plug that into the monitor and it would at least be only a one button affair to switch between which unit the monitor paid attention to.
Best Kid iPad Apps
CanStick
  • Last login:May 02, 2004, 12:39:58 pm
    • CanStick Controls
« Reply #2 on: August 01, 2003, 08:20:40 pm »
I will try to answer these for you:
1)  Yes, you can use a KVM box.  The one I have uses a special hotkey sequence on the keyboard to switch between computers (or computer and dreamcast).  On mine, you have to quickly hit the left shift key twice in a row.  Probably not too good for a MAME cabinet, though    ;)  But I think it can be programmed to whatever sequence you want.  I don't actually have this hooked up yet, but should this weekend.  I don't see why it shouldn't work...
2)  You should be able to...but I will know after this weekend too...
3)  The grounds hook up to the ground on your Ipac (or whatever keyboard encoder you use).
4)  Run the audio out of the dreamcast VGA box into the line input on your computer's sound card...
Hope this helps a bit....
Terry.
crashdmj
  • Hulk smash!
« Reply #3 on: August 01, 2003, 09:57:36 pm »
How do you run the audio out of the dreamcast VGA box into the line input on your computer's sound card?
KVM box?? Damn more parts to buy (what do people who dont use these do)
Anyone else.
Derek
« Last Edit: August 01, 2003, 10:02:35 pm by crashdmj »
CanStick
    • CanStick Controls
« Reply #4 on: August 01, 2003, 10:02:06 pm »
Well, the dreamcast VGA box I have has an audio output...it is a 1/8" stereo jack (the same as the computer line input).  I don't know if all the VGA boxes have them or not....if not, then does yours have RCA audio outputs?  If so, then you can use these with an adapter to go into your sound card.
Hope this helps...
Frostillicus
  • Arcade Artist
  • Last login:April 18, 2023, 07:36:29 am
    • My MAME cabinet site
« Reply #5 on: August 02, 2003, 03:17:34 pm »
I use a cheap VGA switch box from ebay, works great.  I also use an small audio switch box to...switch between the 'DC VGA-box' audio and the pc audio.
My cab turns everything on with one switch, so going in to turn off the PC then turn on the DC would be a pain.  I don't believe a KVM switch box would work in my case, and it was quite a bit more expensive than the 12 dollar vga switch box I use.
I have all the switches and the DC right in front of the cab so I just open the door and switch them over.  You have to go in to put in a disc, so it's not that big of a deal.
crashdmj
  • Hulk smash!
« Reply #6 on: August 04, 2003, 01:02:48 pm »
Where can one find these switch boxes?
Derek
Frostillicus
  • Arcade Artist
« Reply #7 on: August 04, 2003, 02:15:20 pm »
I got my VGA switch box off of ebay.  Thanks to canstick, I now can do away with the audio switch box (it was only like 10 bucks anyway).  Doing the line-in thing.
Get the blue translucent sega VGA box. The others might work too, but I know this one works for sure.   Pic of the box attached.   It was 12 bucks at local Software Etc.
for the VGA SWITCH BOX, this is the exact one I got, from the same person.  I just did the buy it now for 14.96.  No idea if the SVGA made any difference from regular VGA auctions she had (check her other items).  But all I need is two inputs.
crashdmj
  • Hulk smash!
« Reply #8 on: August 04, 2003, 03:23:50 pm »
Can you explain the audio in line thing.
Derek
Frostillicus
  • Arcade Artist
« Reply #9 on: August 05, 2003, 02:13:36 pm »
Derek
Take the audio from the DC and plug it into the line-in jack on your soundcard (or the microphone jack).
