Author Topic: How is everyone fixing "Recommended Games (0)" (mameinfo.dat) these days?  (Read 5201 times)
Triangel7D
  • Last login:September 10, 2017, 01:06:09 pm
Just did a lot of searching on this topic last night, and there hasn't been any discussion in the last two years. It's a feature I'd really love to work in MaLa (I love discovering new games).
Are people still fixing the "Recommended Games:" lines (getting rid of "(Airforce 2)" for example) as outlined in this post?
http://forum.arcadecontrols.com/index.php?topic=71074.msg731384#msg731384
If so, has anyone found a "smart find/replace" program out there, so hand-correcting each one isn't necessary?
Someone had posted an old corrected data in the thread below, but I cannot seem to unzip his archive (even with WinZip).
http://forum.arcadecontrols.com/index.php?topic=84625.0
Also, if I end up correcting my own mameinfo.dat (.138), is that something I can post to the File Repository?
« Last Edit: May 23, 2010, 01:22:56 pm by Triangel7D »
capitaineflam25
  • Last login:December 12, 2014, 12:03:52 pm
Recommended games is a feature i appreciate a lot too.
In order to wait for a fix, you can use my corrected mameinfo.dat: http://www.moremce.com/dl/mameinfo_0.138_recommended_clean.zip
I've done a regular expression search and replace with notepad2 (http://www.flos-freeware.ch/notepad2.html): Recommended Games (.+): -> Recommended Games:
Triangel7D
capitaineflam25 -- I've been off the board for a while (just had my 2nd child) and just saw this now. This is fantastic! Thank you so much!
empardopo
  • Last login:September 12, 2025, 11:01:38 am
    • My personal forum
I don't understand this feature!
Can anyone tell me its value?
Thanks in advance.
Triangel7D
Thanks in advance.
If you're playing, say, Pac-Man, you can have Mala pull up the Recommended Games list to tell you similar games you might also like -- like Make Trax or Mousetrap or Lock & Chase. For me, it helps me find games I've never heard of (and there are a lot in Mame).
The Recommended Games list in mameinfo.dat changed so Mala has a hard time reading it (every game shows 0 recommended games). capitaineflam25's fix quickly fixes the file.
empardopo
    • My personal forum
OK, now yes!
That's great but how can i use it with my lauout?
Thanks a lot!
Triangel7D
OK, now yes!
Thanks a lot!
I can't get to my machine at the moment, but there's options to open sub-windows in Mala (one button to open the windows, one to cycle through -- both configurable). It cycles through Marquees, Cabinets, Recommended Games, Game History, etc.
empardopo
    • My personal forum
Please, when you can get to your machine, tell me how can i configurate it in my MALA!!
Thanks in advance.
Triangel7D
Thanks in advance.
Point your Mala to mameinfo.dat in this configuration box:
http://wiki.arcadecontrols.com/wiki/Mala_Config#Additional
Triangel7D
Thanks in advance.
...then in this window...
http://wiki.arcadecontrols.com/wiki/Image:Mala_OptionsCKA.JPG
...configure the buttons for Menu open/close and Menu Select.
empardopo
    • My personal forum
Thanks a lot!
I'm going to test it.
Greetings!
kernelpanic
  • Last login:December 12, 2010, 04:01:00 pm
Re: How is everyone fixing "Recommended Games (0)" (mameinfo.dat) these days?
« Reply #11 on: September 10, 2010, 09:43:36 am »
This works great! thanks! :cheers:
empardopo
    • My personal forum
How can i configure MALA?
I've tested it but it doen't work.
Thanks in advance.
kako121
  • Last login:August 18, 2022, 01:54:05 pm
Thanks in advance.
One must modify the mameinfo.dat (I think) so that MaLa can read it.  One must configure nothing more :)
If you want I give you mine.
Saludos  :laugh2:
empardopo
    • My personal forum
How i can modify that file?
If you don't mind gime me your file.
Thanks! (Muchas gracuas)  :notworthy:
