Author Topic: Received my new panel, but need a little help  (Read 2080 times)
shateredsoul
  • Last login:January 25, 2013, 08:23:51 pm
« on: May 18, 2010, 08:22:57 pm »
So when I place the joystick over the wood (3/4") just too see how it looks and the happ 8 way sticks out but not as much as i'd like it to stick about as much as in this joysticks
but when I place it to test it out, it sticks only enough for the rubber part to stick out, how can I make it more like in the pic?
TheGameFan
  • Last login:September 14, 2011, 12:21:42 am
Re: Received my new panel, but need a little help
« Reply #1 on: May 19, 2010, 01:41:32 pm »
If I'm reading you're question correctly, the answer is that you need to route a groove for the base in the bottom of the CP. THis will bring the stick higher. Also, there is a spacer that you cna use to raise it a bit.
In the works: Full sized Capcom fighter cab, QBert Mini Bartop, Bartop JAMMA / MVS1, Centipede Cocktail restoration
DashRendar
« Reply #2 on: May 19, 2010, 01:44:41 pm »
So when I place the joystick over the wood (3/4") just too see how it looks and the happ 8 way sticks out but not as much as i'd like it to stick about as much as in this joysticks but when I place it to test it out, it sticks only enough for the rubber part to stick out, how can I make it more like in the pic?
Holy run-on sentence, Batman!  Throw some punctuation in there!  :lol
syph007
« Reply #3 on: May 19, 2010, 01:49:35 pm »
It's probably bottom mounted right?  Top mount instead, it will sit up higher.
lilshawn
  • Last login:Today at 05:55:53 pm
« Reply #4 on: May 19, 2010, 02:14:07 pm »
ya, if you want to end up on crapMAME.
in the humble words of crapMAME:
And of course, exposed plates still suck.
syph007
« Reply #5 on: May 19, 2010, 02:33:01 pm »
Top mounted meaning routing a slot ABOVE the wood not below, not exposed mounting plates.  Not the same thing.
DashRendar
« Reply #6 on: May 19, 2010, 02:35:18 pm »
Right- if you want to bottom-mount the stick, but it's too low on the top side, you'll need to use a router and route out some of the wood so it's higher.
Depending on the thickness of the wood will affect how much material you can eliminate.  There are numerous threads in the Woodworking forum that talk about bottom mounting (or under mounting) joysticks.
Another option, for certain sticks, is to get longer shafts.
Ultimarc 360s and Sanwa JLW sticks can both use the long shafts that Divemaster sells.
TOK
  • The Game Always Wins
« Reply #7 on: May 19, 2010, 10:02:20 pm »
I think I did what you want to do... You route a square in the top of the panel and have it sit below the plexi/overlay.
I did two other things with mine... I used t-nuts so there are no bolts through the plexi and I also put the dust washer under the plexi. The top of the stick base is sunk down for clearance to do this.
There is some debate about the proper installation of the dust washers, and there might not even be a correct way, but I think they look kind of sloppy up top (and conceal the art!).
shateredsoul
« Reply #8 on: May 19, 2010, 10:12:22 pm »
thanks for the advice everyone!... I think I"m going to mount it underneath to see how i like it, if I don't like it i'll look into all these options
« Reply #9 on: May 19, 2010, 10:50:26 pm »
+1 on the dust washer comment, I wish I'd routed space for them underneath the formica on the top of my CP.
But, in the end, I think I came up with a relatively decent solution, at least for my cab.   ;)
http://forum.arcadecontrols.com/index.php?topic=88515.msg1073324#msg1073324
