Author Topic: CueLight Interactive Pool Table System  (Read 3835 times)
gryhnd
« on: May 10, 2010, 03:10:14 pm »
Pun fully intended: this is the balls.
Completed: No Name Upright
  • Last login:November 09, 2025, 07:06:54 pm
Re: CueLight Interactive Pool Table System
« Reply #2 on: May 10, 2010, 03:27:27 pm »
So you hang something above the table?  Weird.  It says transform ANY table so I imagine this is how it is done.
NiN^_^NiN
« Reply #3 on: May 10, 2010, 06:25:32 pm »
I saw this a while ago and did a quick test rig to see how well it worked
I just used a pico projector and a laptop to test and use one of them flash webpages that use ur camera to make ripples when movement is seen and it worked well altho the issue was all the flash webpages that detected webcam movement showed the cam image and made ripples of that so seeing your hand on the table then ur projected hand on the table aswell wasn't a good look.
Never did find any programs that used webcam movement but didn't use the webcam image to manipulate so i never bothered to go further with my testing.
I did however play a flash close of advance wars on the tabletop with a led pen and a wiimote which was pretty cool moving units on the table and making them attack
gryhnd
« Reply #4 on: May 10, 2010, 07:44:56 pm »
Do a search, nüb:   ;)
http://forum.arcadecontrols.com/index.php?topic=96515.msg1016971#msg1016971
Not a noob. Did a search, got nothing. I'll be sure to clear my posts through you first next time though  :o ::)
missioncontrol
  • MC-Retro says Wot!
  • Trade Count: (+13)
« Reply #5 on: May 11, 2010, 10:08:12 am »
did you try checking the library for a sense of humor?
« Reply #6 on: May 11, 2010, 10:08:48 am »
 :duckhunt
gryhnd
« Reply #7 on: May 11, 2010, 10:49:11 am »
It was already checked out. I put a hold on it though.  :laugh:
Sorry, I do have a great sense of humor, but sarcasm doesn't always make everyone laugh at all times. Clearly HarumanS' comment rubbed me the wrong way.
« Reply #8 on: May 11, 2010, 11:09:37 am »
Clearly.   ::)
Hoopz
  • Last login:Yesterday at 07:08:07 am
  • Intellivision Rocks!
« Reply #9 on: May 11, 2010, 11:20:41 am »
Doesn't rubbing each other belong in the meet up forum?
« Reply #10 on: May 11, 2010, 11:21:58 am »
I thought that was the "Meat up" forum...
Hoopz
« Reply #11 on: May 11, 2010, 11:37:47 am »
Careful, PETA will freak out about you talking about meat.
