Author Topic: full sideart install  (Read 1597 times)
doteater
  • Last login:May 31, 2012, 08:04:13 pm
« on: April 22, 2010, 08:49:07 pm »
Hello, I'm not really sure where to post this so move it if it doesn't belong here.
I picked up a tapper cab a few months ago that has been converted. It has laminate put over the entire cab and maybe some other artwork under that. I put in an order and have received sideart and kickplace replacements(original Budweiser art). Now I have a few questions on how to go about this, I done some searching on the forum and found some answers but not enough.
At first I thought I could just put the artwork on top of the laminate. Now I think the best route would be remove the laminate and remaining artwork, power sand, few coats of primer, fine sand and place the vinyl artwork on that?
Also when I do put on the vinyl art how do I go about it? Seen a few vids of taking measurements to center it, tape in place and squeegee it on. The art is the entire sides of the cab, could I just use some heavy objects to keep it in place once lined up and  then peel/squeegee down? Do I take the outer layer off once stuck on or do it before? Sorry if I missed these in my searches and thanks for any help I can get.
bkenobi
Re: full sideart install
« Reply #1 on: April 22, 2010, 10:06:30 pm »
Duh.  The answer is obviously....
Very Carefully!
 :laugh2:
MameMaster!
  • Engage number one!
    • Mame Invaders!
« Reply #2 on: April 23, 2010, 11:23:40 am »
Why remove the laminate? It looks clean and smooth. Why mess up that surface?
In my experience with Side art-- every tiny imperfection shows up on your peel/stick art. I've impulsively rushed a few projects in my time and got a nice, but not a great finish.
My vote is to leave it on and put your art on top of it. Good luck!  :cheers:
bkenobi
« Reply #3 on: April 23, 2010, 12:14:10 pm »
Is that metal shelf on either side of the CP a cup/change holder?
eaconner
  • Last login:February 27, 2013, 11:15:42 am
    • WV Arcade Club
« Reply #4 on: April 23, 2010, 12:36:00 pm »
It looks like a cup holder from a Tapper machine.
MameMaster!
    • Mame Invaders!
« Reply #5 on: April 23, 2010, 12:50:27 pm »
cupholder.  :cheers: :cheers:
doteater
« Reply #6 on: April 23, 2010, 03:19:10 pm »
Thanks for the input. The laminate is in good shape. A few chunks missing and cracks around the edges, bondo should fix it. Should I put a few coats of primer on the laminate or just patch it up and put the art on?
