Author Topic: Design/layout ideas  (Read 4299 times)
Flake
  • Last login:January 11, 2025, 01:16:20 pm
  • I am Evil Homer....I am Evil Homer....
Design/layout ideas
« on: April 15, 2010, 04:07:53 pm »
I am going to be building a new house within the next few months and am in the process of designing my floorplan as we speak.  I will want to incorporate a wall mounted touchscreen jukebox in/on the wall as I currently have in my house now.  Since I am building this thing from scratch I will have all the speaker wires run to the area the computer will reside.  My current setup relies on a 2.4 GHZ transmitter to channel the signal to a receiver plugged into my stereo receiver.  In addition, my surround sound speakers in my basement used for TV viewing are also the same speakers used for the jukebox.
Question -
If could start from scratch with the freedom to incorporate all your ideas what would they be?
What would you do differently the second (or third/fourth) time through?
Could be anything from computer specs to component hardware to speakers/speaker wire or cool lighting effects......whatever....
I would be interested in getting some ideas.
Thanks in advance!
Re: Design/layout ideas
« Reply #1 on: April 15, 2010, 04:13:20 pm »
Run ethernet lines everywhere!  :)
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
« Reply #2 on: April 16, 2010, 05:23:49 am »
Hi,
I would make those ethernet cables Cat6 minimum and run a few multicore cables for future use and put in some heavy duty speaker cables in area's you think you may have a need for and run them all back to your basement area or where ever you think your main controls will be installed.
Regards
Alan Hood
ami-man
Flake
« Reply #3 on: April 19, 2010, 09:53:42 am »
What is a multi-core cable?
BobA
  • What Me Worry?
« Reply #4 on: May 03, 2010, 08:10:41 pm »
Lots of choices for multi core cables.   You have to sort of know what types you may use.
Cable Info
kizer
    • Links4jeeps.com
« Reply #5 on: May 21, 2010, 06:08:17 pm »
When I wired up my place I installed Cat5e even for phone line. I knew in the end if I ever needed I would have spare wire within the Cat5e.
caesar
  • Last login:July 20, 2013, 09:00:50 pm
« Reply #6 on: June 03, 2010, 11:55:29 pm »
Hello,
   I'm not sure how your connecting your touch monitor to the PC (VGA?), but the distance should be no longer than 15ft.
Definetly get away from using that 2.4ghz transmitter. I also have a 2.4 ghz telephone & a Linksys 2.4 ghz router. Lots of problems :badmood:
http://forum.arcadecontrols.com/index.php?topic=98605.msg1041950#msg1041950
« Last Edit: June 03, 2010, 11:57:10 pm by caesar »
urbecrisch
  • Last login:March 30, 2025, 01:11:38 pm
  • I was the S**T back in '82
« Reply #7 on: June 04, 2010, 08:02:25 am »
Not sure if this is something you need for sound, but I use it and it works perfect for my juke (no hum).
http://www.fxsound.com/mp3connector/index.php?vendor=0&subvendor=0&plus=0&refer=14
