Author Topic: Saving snaps & changing keystrokes  (Read 2303 times)
IG-88
« on: April 10, 2010, 05:07:23 pm »
Got a couple small questions\issues. My NES emu (nestopia) requires alt+x to exit. Is there a command line string to get this to work with mala's esc button press? Or perhaps another way?
And, is there a way to save snaps in Mala like you can do in Mame with the F12 key?
I did some searching but didn't find much help.
-HarumaN
Eddie_Brock
  • Last login:February 26, 2014, 12:00:34 pm
Re: Saving snaps & changing keystrokes
« Reply #1 on: April 11, 2010, 12:56:45 pm »
I'm not too sure about Nestopia, but ZSNES allows you to bind any command to any key/button of your choosing. You can setup hotkeys for save&load-states, screenshots and exiting. You could try a different emulator and see if it helps at all.
I realize this may not be the answer you were looking for.
IG-88
« Reply #2 on: April 11, 2010, 09:10:03 pm »
well I think I figured out the esc button issue, now just need to get the snaps thing done right.
-HarumaN
