Author Topic: MaLa and GP-Wiz40 - "buttons" 17 through 32 don't appear to work- FIXED  (Read 5094 times)
nick3092
  • Last login:March 22, 2022, 03:57:28 pm
I have a GP-Wiz40 and am using MaLa. However, I've noticed "buttons" 17 through 32 don't appear to work. In the "check" tab they show up correctly. But when I asign them to a function, they don't work.
Is this a known issue, or am I just lucky? :) I'm using the beta 1.6g version.
-Nick
« Last Edit: April 25, 2010, 07:34:36 am by loadman »
loadman
  • Moderator
    • MaLa
Re: MaLa and GP-Wiz40
« Reply #1 on: April 06, 2010, 11:18:05 pm »
-Nick
Ahhh At last a beta tester... yes?
I don't have a Joystick with so many buttons.
Thanks for reporting
I will have a look
nick3092
« Reply #2 on: April 06, 2010, 11:26:48 pm »
I will gladly test. I'm just building my cab right now. So it's certainly not 100% functional. But I'm glad to help out any way I can!
loadman
  • Moderator
    • MaLa
« Reply #3 on: April 06, 2010, 11:44:46 pm »
I had a look through the code and can't see any mistakes?
I think it is odd that the buttons work in the config tester but not mala itself as the control share code.
I might send you a version with extra logging for you to test
« Last Edit: April 07, 2010, 01:50:20 am by loadman »
nick3092
« Reply #4 on: April 07, 2010, 06:29:02 pm »
Yeah, I thought it was odd too.  But I went through and tested every input/"button" till I found where they stopped working - 17.  It could just be coincidence, but those are all the buttons on the second row of the tester.  Not sure if there is a correlation there.
loadman
  • Moderator
    • MaLa
« Reply #5 on: April 08, 2010, 03:34:44 am »
Mystery?
I will PM you a location to download a test version later  ;D
Ahh I treated myself and bought one.
I will find out soon enough what the problem is
loadman
  • Moderator
    • MaLa
« Reply #6 on: April 16, 2010, 01:18:34 am »
How long does it take to get here.  ???
nick3092
« Reply #7 on: April 17, 2010, 08:52:10 am »
I've placed several orders from GGG.  I always get them pretty quick.  But then again, I'm in the States.  ;D
loadman
  • Moderator
    • MaLa
« Reply #8 on: April 19, 2010, 04:08:05 am »
Well , Ultimarc gear get's here in a week   ;D
loadman
  • Moderator
    • MaLa
« Reply #9 on: April 20, 2010, 08:06:30 pm »
It Arrived .     :applaud:   I will play with it tonight  ;D
« Last Edit: April 20, 2010, 11:11:06 pm by loadman »
loadman
  • Moderator
    • MaLa
« Reply #10 on: April 23, 2010, 11:37:30 pm »
Hi I confirmed the problem.
Will check the code and see if I can fix this.
It might be hard problem if the default Joystick call back does not support this..
Stay tuned
nick3092
« Reply #11 on: April 24, 2010, 12:23:41 am »
Stay tuned
Glad to know I'm not crazy. ;)
loadman
  • Moderator
    • MaLa
Re: MaLa and GP-Wiz40 - "buttons" 17 through 32 don't appear to work
« Reply #12 on: April 24, 2010, 05:53:09 am »
Yup,
Good news is I can fix ...but it will take a while. Basically replacing the way Joystick is used in MaLa.
I no doubt will break something that someone will tell me about later on   ;D
I promised to add the 'shift' feature to Joysticks anyway....  and it is in the same area
« Last Edit: April 24, 2010, 05:54:43 am by loadman »
loadman
  • Moderator
    • MaLa
« Reply #13 on: April 25, 2010, 01:48:06 am »
D'oh!
Just changing 'WORD' to 'Int64' in a few places got me up to 31 buttons.   ;D   Easy, once I worked out how the lib code worked.
 Not sure why button 32 does not work yet but 31 or less does  ???
[edit]
FIXED  ;D
[/edit]
Case Closed
« Last Edit: April 25, 2010, 07:10:02 am by loadman »
nick3092
Re: MaLa and GP-Wiz40 - "buttons" 17 through 32 don't appear to work- FIXED
« Reply #14 on: April 25, 2010, 02:04:13 pm »
Yay!  Looking forward to the next release!  Thanks! :applaud:
loadman
  • Moderator
    • MaLa
« Reply #15 on: April 28, 2010, 12:06:54 am »
Actually (for anyone who cares) I probably went overboard increasing its type. I might peg it back to LongWord rather than Int64
