Author Topic: How to make a volume knob ??  (Read 8057 times)
Nacimroc
  • Last login:October 20, 2015, 03:46:25 pm
« on: March 23, 2010, 10:04:50 pm »
How do i go about making a volume control knob to control the volume of my amp ? I bought a 50k pot and want to change the volume on my amp and not my pc. It would be a pain to try unsolder and re-solder the pot on the amp's board.
The way its connected now is:  PC (via phono cable) -> mini ebay amp -> sub (that uses passthrough) -> speakers
  • Last login:February 22, 2026, 09:34:29 am
Re: How to make a volume knob ??
« Reply #1 on: March 23, 2010, 10:50:36 pm »
Search for "Amis LC-1 LC1 Remote Volume Bass Sub Control Knob" on fleabay.
Simplest way I can think of...
Ginsu Victim
  • Comanche, OK -- USA
« Reply #2 on: March 24, 2010, 12:35:40 am »
Oscar Controls mirror on BYOAC
http://mirrors.arcadecontrols.com/OscarControls/volume/index.shtml
That's what I used and it works great.
Nacimroc
« Reply #3 on: March 24, 2010, 09:20:14 am »
Thanks! Was exactly what I was after!
Zebidee
  • Trade Count: (+9)
  • Last login:Today at 03:36:27 am
« Reply #4 on: March 27, 2010, 01:10:29 pm »
You should check out this description of how to install a volume pot. It makes everything very clear and has great pictures:
http://scarvell.net/wiki/index.php?title=VOLUME_CONTROL_MOUNTING_AND_WIRING
IG-88
« Reply #5 on: April 01, 2010, 09:07:56 pm »
Because I'm such a cheap bastiage, can you guess what these are?
-HarumaN
protokatie
« Reply #6 on: April 01, 2010, 09:43:29 pm »
Ooo, nice! Using Wire Nuts as knobs! I'll have to remember that!
IG-88
« Reply #7 on: April 01, 2010, 09:50:09 pm »
Sounds silly I know but they really don't look too bad... ;D
-HarumaN
Nacimroc
« Reply #8 on: March 29, 2011, 04:06:20 pm »
Ok, finally got around to making this but ran into some trouble. I ordered 2 of these:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&_trksid=p4340.l2557&rt=nc&nma=true&item=300517743651&si=xN0AYcNi8CWuD3lp0E9yX4Jv4Fs%253D&viewitem=&sspagename=STRK%3AMEWNX%3AIT#ht_500wt_922
BUT.....I am only getting left channel.
I tried the second pot just to make sure, but figured I'd ask the experts here before hacking up another cable to test.  Im using a 3.5mm to phono cable. (was a tv out cable, but i disregarded the video lead) So just red and white. I have wired this twice and checked it loads of times against the two links above and I can't see the problem.
I tried 3 different inputs on my amp (which has both channel working fine - tested to make sure)
Zebidee
  • Trade Count: (+9)
« Reply #9 on: March 30, 2011, 02:01:40 am »
Maybe your PC is outputing mono?
Nacimroc
« Reply #10 on: March 30, 2011, 10:06:29 am »
Tried a PC and 2 phones and all just output single channel. I reckon it is either the cable (doubtful as I checked it before I cut it up and I joined in twice to 2 pots in different parts of cable.) OR the 2 pots are faulty maybe ?   So frustrating.
SavannahLion
« Reply #11 on: March 30, 2011, 10:41:23 am »
The male four conductor 3.5mm (TRRS) is probably shorting out in the three conductor 3.5mm (TRS) female. I've seen this behavior when plugging in mono cables into a stereo jack. I believe the right channel shorts directly to ground.
Of course the right channel could be floating or going through the video side. Not sure. can't remember what happens between a TRRS to TRS there.
When you tested it, did you plug it into whatever used three phones or did you test it directly in the setup you have there?
Nacimroc
« Reply #12 on: March 30, 2011, 12:27:33 pm »
SOLVED!!!  ;D ;D
One of the output cables from the pot to the amp was faulty and shorting! When you said shorting I said I'd check and discovered it!
Thanks again for help! Still best forum around.  :applaud: :applaud:
« Last Edit: March 30, 2011, 02:02:08 pm by Nacimroc »
TheSlim
  • Last login:September 27, 2015, 10:11:37 am
« Reply #13 on: March 30, 2011, 09:04:59 pm »
This is a bit off topic but anyone know the best way to do a volume knob when I am using a LCD montior with built in speakers and the sound and video are coming from a HDMI port.  I build a slim cabinet with this set up and would like a volume knob.
« Reply #14 on: March 30, 2011, 09:58:14 pm »
It a bit on the pricey side, and I couldnt get mine to work reliably, but someone on here has a write up on how to fix it.
A Griffin Powermate plugs into your usb port and controls windows sound by turning it's knob.
Search for powermate.
SavannahLion
« Reply #15 on: March 31, 2011, 12:55:16 am »
Wow, that's still being manufactured? I thought that was discontinued...
Blanka
« Reply #16 on: March 31, 2011, 02:44:44 am »
What do you need a volume knob for?
Just program your iPac or so to have a shift key with joystick up/down for volume control.
TheSlim
« Reply #17 on: March 31, 2011, 06:00:39 am »
That taKes up more buttons than necessary.  A knob you be better, I considered a powermate but they look terrible and have bad reviews.
Blanka
« Reply #18 on: April 04, 2011, 03:48:53 am »
What do you mean. P1 start is the shift key already, and you just combine it with the P1 joystick for volume control. That is no extra buttons at all, just some programming. And if you don't like it, you can always drill an extra hole.
