Author Topic: IPAC USB problem?  (Read 2091 times)
mohrt
  • Last login:June 03, 2011, 02:32:42 pm
  • mmm... mame.
IPAC USB problem?
« on: July 27, 2003, 08:36:25 pm »
I'm not sure if this is a problem with USB, Windows XP, IPAC or Game Launcher or a combination of these, so I'll explain here.
My setup is Windows XP, 2Gz CPU, 512MB ram, IPAC4 and OptiPAC both hooked up via USB.
I use Game Launcher for my Front End of MAME. When I have background music running in the launcher, the navigation menu periodically hesitates, meaning that the input doesn't register for about 5 seconds, then it springs back to life. This happens about every 15-30 seconds, and it doesn't seem to matter whether I'm using joysticks (IPAC) or the mouse (OptiPAC) to navigate.
If I disable the background music in Game Launcher, the problem goes away. Also, if I use a NON-USB keyboard or mouse, the problem also goes away (with bg music running.). Any ideas?
TIA
Monte
IG-88
Re:IPAC USB problem?
« Reply #1 on: July 27, 2003, 10:32:05 pm »
Try Andy Warne, he has helped me out with my recent ipac woes!
-HarumaN
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: July 28, 2003, 03:25:37 am »
TIA
Monte
What sound card do you have?  If it's an on-board card, or has bad/old drivers, it might be conflicting with the USB hardware/driver.
Robin
Knowledge is Power
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #3 on: July 28, 2003, 05:19:31 am »
Yes it could be a driver issue. You could try going into Control Panel, Device Manager and uninstall (right click) all USB devices and controller. Then reboot and let the drivers re-install and USB devices re-detect.
On the sound card side, recent on-board codec-based sound chips seem to have driver issues sometimes. Might be worth checking for a later driver version.
Andy
mohrt
  • mmm... mame.
« Reply #4 on: July 28, 2003, 09:57:12 am »
I bought an Epox motherboard with onboard sound, but the first board I got had a hardware problem (no sound). I got the board replaced and the second board was also defective (only left channel sound). So I gave up, disabled onboard sound altogether and went with a SB 16 PCI card, I'm using the default XP drivers for it.
I'll try the USB driver reinstall.
