Author Topic: Best way to attach removable control panel?  (Read 1698 times)
gdilly
  • Last login:April 03, 2025, 01:27:12 pm
  • www.gdilly.com
    • Arcade Ramrod - www.gdilly.com
« on: February 02, 2010, 08:05:37 pm »
I have a large 4-player contol panel that I sometimes need to remove and then reattach.  I am currently just using large screws to reattach the cp and have found this to be very cumbersome.  I've been searching through the older posts regarding this but all the links/pictures for solutions are dead.
Does anyone have any solution for good way to attach the panel that will be easy to remove/reattach and will still be sturdy?
« Last Edit: February 02, 2010, 10:05:35 pm by gdilly »
Chuck Norris was originally in Street Fighter II, but was removed by Beta Testers because every button caused him to do a roundhouse kick. When asked about this "glitch," Norris replied "What Glitch?"
Re: Best way to attach removable control panel?
« Reply #1 on: February 02, 2010, 11:47:36 pm »
Use cocktail clips or latches.  http://www.arcadeshop.com/parts.htm.  Do a "find" for latch.
NickG
  • Last login:September 27, 2025, 08:06:19 am
  • Dig.
    • My Projects Page
« Reply #2 on: February 02, 2010, 11:49:26 pm »
Tension latches are very convenient, once installed.  If you cannot fit such latches to your design, you may be able to utilize giro-bolts as I did.
