Author Topic: 6 in 1 jamma  (Read 2209 times)
Love5508
  • Last login:April 09, 2010, 05:23:24 am
6 in 1 jamma
« on: February 01, 2010, 01:55:48 am »
Just picked up a 6 in 1 jamma connector so I can have more than 1 game in my cabinet but I'm kinda confused.  I have MK2, UMK3, MK4 right now and will be picking up a Killer instinct 1 or 2 a 60 in 1 jamma pcb and a capcom 18 in 1 jamma pcb soon.  My problem is that I know the mortal kombats all require the -5v and diodes to be soldered into the jamma selector but does Killer Instinct or the multi boards require that too?  Just need to know if I need all 6 slots modified to have the -5v for sound and the diodes soldered in.  Any help? ???  confusing...
rusolinio
  • Last login:December 14, 2010, 08:21:22 pm
Re: 6 in 1 jamma
« Reply #1 on: February 01, 2010, 10:58:31 am »
I came across this issue when i wanted to use KI1+2, UMK3, and a jpac for a mame pc all in one KI2 cab. There was a member called jimkirk who helped me out with a diagram to install 12v relays to both supply the games that need the -5v, and also cut the -5v to each slot when not using.
You can view my original post with Jim's reply here:
http://forum.arcadecontrols.com/index.php?topic=85941.msg907616#msg907616
Ive been using this board for just over a year now with the above mentioned games installed with no issues whatsoever. Hope this helps.
