Author Topic: Simple Ipac2 question..  (Read 960 times)
RedSquirrel
  • Last login:September 18, 2003, 12:07:55 pm
« on: July 24, 2003, 07:33:44 pm »
Okay this is for grounding with the ipac. Why is there two ground ports on the ipac? From the pic on ultramarc you just use one, and daisy chain everything.
Or should it go from the ground to say P1 (joy and buttons) and then P2 (joy and buttons) and then back to the other ground port?
Thanks for any advice..
Apollo
    • Eight Bells
Re:Simple Ipac2 question..
« Reply #1 on: July 24, 2003, 07:41:41 pm »
Well you may want to daisy chain all the player 1 controls together and have them in one ground and daisy chain player 2 together and have them in the other ground. That's usually how it is done. It helps down the track if you have any wiring faults, you can halve the number of connections you have to check.
RedSquirrel
« Reply #2 on: July 24, 2003, 07:45:04 pm »
Thanks, thats what i was thinking too! Ah not long till i wire up my cp, just got to give it a paint tommorrow..
paigeoliver
  • Awesome face!
« Reply #3 on: July 24, 2003, 09:26:53 pm »
On mine I sent one of the grounds up to the control panel, and then sent the other one down to the coin door and service switch area.
