Author Topic: avi in Front End  (Read 1757 times)
acidblue0
  • Last login:January 11, 2020, 11:50:52 pm
avi in Front End
« on: January 30, 2010, 10:19:58 pm »
Where do I put my avi files so that front end plays the avi instead on screen shots?
Comtek
  • Last login:June 02, 2017, 07:17:42 am
Re: avi in Front End
« Reply #1 on: January 30, 2010, 10:38:44 pm »
what frontend are you using
if your using mala i just opened the the mll file with mala layout editor and layed an avi block over the snap block and by default avi is shown on the top
acidblue0
« Reply #2 on: January 30, 2010, 10:50:24 pm »
Maximus Arcade
Comtek
« Reply #3 on: January 30, 2010, 11:29:51 pm »
http://www.maximusarcade.com/index.php?option=com_content&view=article&id=97&Itemid=59#misc
SETUP PREFERENCES: CONFIGURATION: LAUNCH
 as long as the right dir's are set and the names are right it should over lay them as well with video being the top layer
shateredsoul
  • Last login:January 25, 2013, 08:23:51 pm
« Reply #4 on: January 30, 2010, 11:58:39 pm »
right so just go under each emulator and tell it where to find your videos OR you can just have a folder in the same folder where you have your emulator and label it videos (or was it video? or vids... hmm) and when you add the emulator it adds the videos folder automatically, same thing for snaps.
Nacimroc
  • Last login:October 20, 2015, 03:46:25 pm
« Reply #5 on: January 31, 2010, 09:57:00 am »
I used a program called "fuzzy renamer" to match all the file names of my videos and images to the roms. Then just pointed Maximus arcade to look in each folder and both show up. Images load first on mine as they show up immediately unlike videos.
acidblue0
« Reply #6 on: January 31, 2010, 01:58:28 pm »
Thanks. That worked
