Author Topic: Mame on a stick  (Read 46648 times)
kop
  • Last login:November 06, 2011, 04:30:51 am
Re: Mame on a stick
« Reply #40 on: February 18, 2010, 06:40:40 am »
Update:
Stuck the base together. Pretty heavy, but not as heavy as I thought it would be moving it around.  Still most definately a 2 man lift though.
Re: Mame on a stick
« Reply #41 on: February 18, 2010, 06:58:44 am »
Awesome work...  for some reason, I thought this was a thread about MAME on a thumb drive, so I've been skipping it.  Nice metal work!   :cheers:
Re: Mame on a stick
« Reply #42 on: February 18, 2010, 07:48:04 am »
You could always let it get rusty for that "old battleship" look  ;)
kop
Re: Mame on a stick
« Reply #43 on: February 22, 2010, 06:57:57 pm »
Cheers.  :)
 :lol  Rust is the natural born enemy of this build. I fear it!  (Although the rustic look would be cool)
kop
Re: Mame on a stick
« Reply #44 on: February 22, 2010, 07:00:33 pm »
Update:
Drilled all the bolt holes out of the frame with a fancy drill press with a magnetic base we have at work.  Made life heaps easier.
djfunkshun
  • Last login:January 13, 2011, 08:37:20 am
  • Geaux Tigers
Re: Mame on a stick
« Reply #45 on: February 22, 2010, 08:09:43 pm »
^We have one of those where i work, just about need the overhead crane to get in to place when working on a sign. And yes they do make life easier.
I.T. manager/ex sheet metal worker
Linux FTW!
http://s240.photobucket.com/albums/ff206/djfunkshun/
http://www.cummingssigns.com/
^ I work here^
kop
Re: Mame on a stick
« Reply #46 on: February 24, 2010, 06:59:02 am »
Update:
Welded 2 bits of 10mm metal at 90 degrees to bolt the frame to the base. The holes are drilled and tapped for the bolts.
I ended up welding little spots evenly on each side of metal to keep a perfect 90 degree angle.  It worked a treat, the bolt holes lined up perfectly. The welding looks awful but should be strong enough.
The outside ground down for the frame to fit.
Bolted on.
All together.
t3design
  • Last login:Today at 06:52:03 am
  • Orange Power! Go Pokes!
    • Cowboy Arcade Project
Re: Mame on a stick
« Reply #47 on: February 24, 2010, 07:42:56 am »
Man, that is sick!
Question: Why did you put the side of the base with the holes for the welds up? I would have thought you would want the smooth solid side up.
Cowboy Arcade Project ThreadCowboy Arcade Project Website
If you are an obsessive/compulsive pyromaniac, you better make sure you wear flame retardant pajamas.
Re: Mame on a stick
« Reply #48 on: February 24, 2010, 07:45:00 am »
I dunno. I think the holes look pretty slick. Gives it a factory/military look.
kop
Re: Mame on a stick
« Reply #49 on: February 24, 2010, 04:55:07 pm »
Man, that is sick!
Thanks.  :)
I will cover the metal base with a wooden surrounding so it won't be seen. The welds are on the top so the bottom is the flattest side.
Re: Mame on a stick
« Reply #50 on: February 24, 2010, 07:20:35 pm »
Aw. Dont' do that! Maybe trim it in wood, but leave the center part bare metal?
I think it looks pretty cool as is.
t3design
Re: Mame on a stick
« Reply #51 on: February 24, 2010, 08:36:08 pm »
+1
The whole thing here is the metal. You gotta stick with that. I can see the holes as "decoration", so I would just grind the welds smooth and powder coat the whole thing. That would look fantastic!
Potts
  • Last login:March 20, 2010, 07:31:09 am
  • I hear what your saying....but your wrong !!
Re: Mame on a stick
« Reply #52 on: February 24, 2010, 10:40:25 pm »
very cool indeed - it's great that people are trying new things.  Good luck with the build kop
cheers
Potts
kop
Re: Mame on a stick
« Reply #53 on: March 01, 2010, 08:43:21 am »
+1
You guys do have me thinking, but I still reckon the base would look better finished the same colour as the rest. This way the rectangular frame will be a different colour and will stand out more.
Love the input though  :applaud:  Other opinions always open your eyes to things you never think of.  Cheers.  :)
cheers
Potts
Thanks Potts.
Trying something different has so far meant spending much more time, money and effort than I thought I ever would.  Will be worth it when i finish though, I should have something pretty unique.
kop
Re: Mame on a stick
« Reply #54 on: March 01, 2010, 08:51:37 am »
Update:
Have fixed the metal brackets I made to the frame.  I will then fix the MDF CP & marquee boxes to the brackets.  The box holding the screen will slide into the slot cut out for it in the middle of the frame.
I found these bolts to use that don't look too unsightly.  I'll paint them up to match the colour of the CP & the rest.
Re: Mame on a stick
« Reply #55 on: March 01, 2010, 08:54:34 am »
Very cool, but boy, that metal base plate looks like a real toe stumper! Better not play barefoot!  :)
versapak
  • I am t3h GAY!!!
Re: Mame on a stick
« Reply #56 on: March 01, 2010, 10:08:24 am »
This thing looks awesome so far.
All these things designed to into one another...
Are you allowing for the size differences you will have after powder coating?
kop
Re: Mame on a stick
« Reply #57 on: March 02, 2010, 01:56:11 am »
 :lol I'll be sure to keep my feet away.  Especially on cold winter mornings  ;D
Cheers.  :)
I've left enough clearance.  I was told beforehand powder coating is pretty thick, so I factored it in.
Nacimroc
  • Last login:October 20, 2015, 03:46:25 pm
Re: Mame on a stick
« Reply #58 on: March 03, 2010, 03:27:05 pm »
This thing is nuts! Can't wait to see it done! Can't picture how it will turn out yet! How heavy is it now ? Can 2 people lift it ?
kop
Re: Mame on a stick
« Reply #59 on: March 08, 2010, 05:05:55 am »
Cheers  :)  It's probably around 90kg all together, with the base making up around 70kg of that.  My dad & I just managed to get it up 2 flights of 8 stairs (with a rest in between each flight :))  It was heavy but doable.
kop
Re: Mame on a stick
« Reply #60 on: March 08, 2010, 05:21:36 am »
Update:
Drilled all the holes in the brackets for the MDF to bolt to.
I also decided AFTER finishing the base that I should rout the power cable through the base for a neater look.  So what would have been a 2min adjustment to a CAD drawing turned out to be hours drilling & grinding a groove in the base. >:(
Drilled
Cut out.
That's all i have to do metal wise so I have now finally dragged it home. (inflicting only minimal back pain in the process.)  ;D
« Last Edit: April 04, 2010, 07:52:10 am by kop »
Blanka
Re: Mame on a stick
« Reply #61 on: March 08, 2010, 06:53:45 am »
What game theme are you gonna use?
Tank?
Next time do better in construction class. OMG, this holds 200 people if used as a column for a balcony. The Maastricht balcony incident would not have happened!
ammitz
  • Last login:April 25, 2017, 07:22:09 am
Re: Mame on a stick
« Reply #62 on: March 08, 2010, 07:39:48 am »
Nice build  :applaud:
Building my first bartop CAB
Havok
Re: Mame on a stick
« Reply #63 on: March 08, 2010, 08:38:11 pm »
So I take you aren't going to have any exposed metal then, since it's in the house already? I thought you were going to powder coat it?
Re: Mame on a stick
« Reply #64 on: March 08, 2010, 10:00:21 pm »
Oh, he's going to assemble the whole thing now just to "make sure it all works" and then the cab'll stay looking just like that for the next year  ;)
kop
Re: Mame on a stick
« Reply #65 on: March 09, 2010, 06:03:40 am »
Tank?
 :lol I agree it's pretty big.  Maybe I should apply for a job in balcony construction? ;D
Cheers.  :cheers:
The base will be covered in wood but the blue metal frame will be powder coated.  I want to get all the woodworking done before I start adding colour.  I reckon this will be a while coming.
 :lol I reckon that comment is right on the money.
kop
Re: Mame on a stick
« Reply #66 on: March 14, 2010, 04:18:53 am »
Update:
Brought all the wood I need this weekend and started by making up some mounting brackets for the electronics running my LCD panel.  I will then glue them onto the back of the panel.
kop
Re: Mame on a stick
« Reply #67 on: March 15, 2010, 06:09:13 am »
Update:
Worked on the cover for my base.
It's a 6mm MDF sheet with a hole cut for the metal frame/pole.
Cut the side coverings.
Glued and screwed them together.
Then stuck them together ready for routing.
  • Last login:Yesterday at 05:02:05 pm
Re: Mame on a stick
« Reply #68 on: March 15, 2010, 01:47:51 pm »
Foot/toe hazard increased though.
kop
Re: Mame on a stick
« Reply #69 on: March 16, 2010, 07:38:45 am »
I've trimmed all that excess off with a router.
It's still sure to provide more than its fair share of toe bashings in its finished state though.  I'm staying away on cold mornings.
kop
Re: Mame on a stick
« Reply #70 on: March 16, 2010, 07:45:41 am »
Update:
Trimmed the top with a router.
Can you tell it's the first time I've used a router? ;D
I've used some builders bog to cover it up that should dry by morning.
wilno45
  • Last login:January 31, 2017, 06:22:42 am
Re: Mame on a stick
« Reply #71 on: March 16, 2010, 07:57:21 am »
Great project you got there,
Just a thought - are you going to powder coat the underside of the base? It's going to leave a slight impression
in your carpet anyway  ;D don't want any rust marks too!
Cheers
kop
Re: Mame on a stick
« Reply #72 on: March 17, 2010, 09:13:13 am »
Cheers
Thanks.  :)
I'm going to cut up some 8mm rubber sheets and place them underneath the base around the edges.  This should make the cab more stable and lift the base off the carpet.
and I've already been sternly warned about my project leaving rust marks on the carpet  ;D
kop
Re: Mame on a stick
« Reply #73 on: March 17, 2010, 09:16:38 am »
Update:
Gotta love builder's bog  ;D  It's like the accidents never happened.
Base cover finished.
kop
Re: Mame on a stick
« Reply #74 on: March 21, 2010, 06:04:03 am »
Update:
Here's the CP box that will house the CPU and other electronics as well.
Nothing groundbreaking here.  It's just a rectangular box with a lid.
Routed a recess for the metal braket to sit in.
Lid on.
kop
Re: Mame on a stick
« Reply #75 on: March 23, 2010, 03:57:14 am »
Update:
Finished up the CP.
Drilled holes for the bracket to be fixed to the wood.
Some of the bolts in.
Filed in the gaps with filler to (hopefully) provide more strength and rigidity.
And finally, I made some sort of a brace out of hardwood that sits on the lip of the metal bracket and is screwed into the MDF.  This should help when angry people playing my cab put a little too much downward force onto the top of the CP.  I felt the screws alone wouldn't be enough.
DashRendar
Re: Mame on a stick
« Reply #76 on: March 23, 2010, 04:11:12 pm »
Looks good.
I see what you guys are saying about wanting to keep the metal look- something industrial, etc.
I'd say that would be perfect if this was going to be in the garage or basement.
Since it's going to be in the house though, gotta keep the appearance clean.   :soapbox:
Due to it being all metal, are you going to run a ground wire from it Kop?   :lol
kop
Re: Mame on a stick
« Reply #77 on: March 27, 2010, 04:30:20 am »
Looks good.
Thanks mate. :)
The metal will be definitely all grounded.  Gotta avoid potential hair frizzing mishaps.
kop
Re: Mame on a stick
« Reply #78 on: March 27, 2010, 04:36:20 am »
Update:
Got the enclosure that will house the monitor done.
A little recess for the frame to sit into.
Wooden blocks in each corner for the LCD to sit on.
kop
Re: Mame on a stick
« Reply #79 on: April 01, 2010, 09:55:57 am »
Update:
Pretty much finished the box that will house my speakers and marquee.
Cut the pieces out and am using a metal bracket similar to the way i made my CP.
Routed out a 8mm lip for the clear plastic cover of my marquee to sit into.
Bolted on.
Filled the gaps.
All together with speaker holes cut.
